As title is it ok to paint intercooler mine is looking horrible now and want to freshen it up with a lick of paint just wanna make sure I don't cause problems
What colour? Have your tried wire brushing it?
I bought my cooler and someone had painted it black and it looked soooooo shit. Just worth keeping in mind.
My intercooler looked a mess when i purchased my V over 3 years ago.
I just sanded it down with wet 'n' dry paper from 800 - 1000 - 1200 - 1500 - 2000 then used a cheap aluminium polish from a local d.i.y shop it came out looking like new and i did the same for all of the piping too.
Ye I have heard this is how to do it but its a lot of work also don't really see many purple ones and my bumper covers a lot of it so it won't be to in ya face.
Also how easy is removing front bumper?
Ye I have heard this is how to do it but its a lot of work also don't really see many purple ones and my bumper covers a lot of it so it won't be to in ya face. Also how easy is removing front bumper?
Just a few bolts and screws, easy
2 bolts to remove the front bumber, they can be found under the wheel arch lining.
Once they are removed to just take off the black trim clips which are located at the top of the bumper (6 iirc)
Be careful when you pull the bumper off as you need to disconnect the fog lights.
2 bolts to remove the front bumber, they can be found under the wheel arch lining. Once they are removed to just take off the black trim clips which are located at the top of the bumper (6 iirc) Be careful when you pull the bumper off as you need to disconnect the fog lights.
Should be alot more than 2 bolts lol.
Oh forgot to mention 2 more bolts right at the bottom too
Lol 2 at the wings. 2 main bolts that go staight in the front next to the foglights.
Then 3 or 4 underneath that go into the subframe.
