Lawless Posted June 19, 2013 Posted June 19, 2013 (edited) Had the car a good couple of years now been on here since I had it thought I'd throw up some pictures up Hopefully it worksFitted mines ecu and fimic on the weekend Edited June 19, 2013 by Lawless Quote
Lawless Posted June 19, 2013 Author Posted June 19, 2013 Pretty basic spec Standard engine and turboCustom stainless exhaust Roose hose kit FimicTrd leads Mines ecu and that's about it Plan is updated fuel pumpManiDecat And up the boost Quote
Lawless Posted June 20, 2013 Author Posted June 20, 2013 Having a slight problem since fitting the fimic can anyone advice me on what to do first of all it was under boosting and felt sluggish So I checked all the intercooler joiners were tight and had a decent length of pipe in them and noticed the studs on the turbo where the hotside pipe were not done up at all it ls almost like there's not enough thread to grab them ?But tightens them up as far as I could feels pretty solid and since then it's making some insane whistling noise and there's hardly any dump coming from the bov? Quote
akyakapotter Posted June 20, 2013 Posted June 20, 2013 (edited) you got a leak then bud some of those pipes look like they have taking a beating sure its not leaking from there or something. Edited June 20, 2013 by akyakapotter Quote
Lawless Posted June 20, 2013 Author Posted June 20, 2013 I definitely have a leak can hear it all the time when on the throttle just can't pinpoint where it's comin from il try putting sealant round the hot pipe Cheers Quote
akyakapotter Posted June 20, 2013 Posted June 20, 2013 it wont help having jublee clips id get mikalor clamps Quote
Lawless Posted June 20, 2013 Author Posted June 20, 2013 The pipes seemed to be In good health only surface damage and the hoses nice and tight The only other thing I think is causing the leak is the studs seem to short and I can't get a decent amount of thread through the nut ? Quote
Lawless Posted June 22, 2013 Author Posted June 22, 2013 Got the hot pipe sorted can anybody tell me what the stock boost pressure is on low and high boost Because not sure if its still leaking slightly somewhere else Quote
jimmymac101 Posted June 22, 2013 Posted June 22, 2013 if i rememeber correctly its 0.65 on low boost and standard boost is 0.8 or 0.85 james Quote
Lawless Posted June 22, 2013 Author Posted June 22, 2013 Hmm only getting .4 on low and .65 on high So she's still leaking Quote
jimmymac101 Posted June 22, 2013 Posted June 22, 2013 Don't hold he to that though buddy I'm not 100% sure Quote
Lawless Posted June 22, 2013 Author Posted June 22, 2013 Ok thanks though dude Anyone else got any info on the stock boost settings so I can check how much it's leaking Quote
Lawless Posted June 22, 2013 Author Posted June 22, 2013 That right mate .4 low and .65 highCheers pal Quote
StarletSr? Posted June 23, 2013 Posted June 23, 2013 Thats good then mate have you noticed a difference with the front mount? Quote
Lawless Posted June 23, 2013 Author Posted June 23, 2013 Thats good then mate have you noticed a difference with the front mount?Yes mate sounds fuckin awesome changed from a hks bov to a greddy at the same time spool up sounds good to !! Little bit more laggy but well worth it In my opinion Quote
Lawless Posted September 29, 2013 Author Posted September 29, 2013 Having a slight problem guys took the beast to work today and while sat on the motorway whenever I put my foot down the temp gauge was going down towards cold and then sat at a constant speed it would go back up Half way any ideas what causing this ? Quote
bucketep91 Posted September 29, 2013 Posted September 29, 2013 Sounds like a thermostat issue. Just replace it, cheap and easy Quote
Lawless Posted October 7, 2013 Author Posted October 7, 2013 Thermostat changed issue sortedNext problem fitted stainless manni and decat last night to find yet another boost issue it's building boost but not as much as before and whistling its tits off no dump it's an obvious boost leak but can't seem to locate it can anyone point me the right direction Thanks Quote
Lawless Posted January 13, 2014 Author Posted January 13, 2014 Purchased a few goodies over Christmas Bought a ct9 hybrid setup Finally got it fitted just after new year absoulutley love it Then I fitted my air filter relocation Leaving it like this for the time being hopefully be sporting some coilovers in the summer Quote
Lawless Posted January 31, 2014 Author Posted January 31, 2014 Bought a catch can setup soon to be going in Also installed my boost gauge Quote
