liamg40 Posted June 26, 2013 Posted June 26, 2013 Just got round to fitting a hks adjustable actuator bought second hand off this forum.Pre set the arm to 123mm to achieve 0.8 boost (correct me if that's wrong)Took it out for a quick test drive and tried it out and the boost nearly went off the dial! (Very briefly of course)I've wound it down four times now one turn at a time and it's still the same, boosting its head off.It boosted just fine on the standard one at 0.65, can these actuators fail or is it me that's failed epically trying to fit it?Also is the little vac hose supposed to run to the turbo or to atmosphere? Quote
liamg40 Posted June 26, 2013 Author Posted June 26, 2013 Could the waste gate spring be knackered??I've just checked the arm that bolts to the actuator arm and there is no tension at all, it moves side to side very easily, Is this normal? Any help appreciated. Quote
AdamB Posted June 26, 2013 Posted June 26, 2013 Thats not normal mate, there should be tension to hold the wastegate shut until the desired boost pressure is hit. Quote
WallaceGlanza Posted June 26, 2013 Posted June 26, 2013 The hose should be connected to the turbo and you lengthen it to turn the boost down, it will have a bit of sideways movement but should be tight to pull out. Quote
liamg40 Posted June 26, 2013 Author Posted June 26, 2013 Thats not normal mate, there should be tension to hold the wastegate shut until the desired boost pressure is hit. Cheers mate, it must be the wastegate spring then because when the actuator is un bolted I can open and shut the wastegate very easy infact it just wobbles about when I touch it. Quote
WallaceGlanza Posted June 26, 2013 Posted June 26, 2013 If the actuator spring is weak it will make the boost lower not higher as the wastegate won't be held shut. Quote
liamg40 Posted June 26, 2013 Author Posted June 26, 2013 I'm gonna put the old standard one back on and see what it's like,I've wound the adjustable one out that far now it's not even starting to boost until over 3.5k revs but still massively over boosts when it hits full boost.Dont know what's going on so I'm gonna put the standard one back on and go from there,Cheers for the help lads. Quote
akyakapotter Posted June 26, 2013 Posted June 26, 2013 ^^^ don't you need to wind it in to raise the boost what your doing there by winding it out is lowering the boost : Quote
liamg40 Posted June 26, 2013 Author Posted June 26, 2013 ^^^ don't you need to wind it in to raise the boost what your doing there by winding it out is lowering the boost :I know mate, my posts explain that it's over boosting so naturally I would be trying to turn it down by winding it out more, Quote
akyakapotter Posted June 26, 2013 Posted June 26, 2013 Ah I see hopefully you get it sorted and you didn't get sold a duff one Quote
liamg40 Posted June 26, 2013 Author Posted June 26, 2013 Could it be the actuator arm that's stuck causing the wastegate not to open?I'm gonna go out now before it gets Dark and see if I can move it manually with my pliers. Quote
akyakapotter Posted June 26, 2013 Posted June 26, 2013 You should just be able to pull on the actuator arm for it to move a bit and the waste gate flap should move easily if you don't have the actuator connected Quote
liamg40 Posted June 26, 2013 Author Posted June 26, 2013 Just got it off and the arm seems ok,I can pull the arm out by hand and there's plenty of tension pulling it back in again,Confused now, I'll crack on in the morning now, cheers. Quote
5T4R7ET N/A Posted June 26, 2013 Posted June 26, 2013 use this guide, see what happens https://home.comcast.net/~ronald_miranda/hksactuator.pdf Quote
WallaceGlanza Posted June 26, 2013 Posted June 26, 2013 (edited) Just got it off and the arm seems ok,I can pull the arm out by hand and there's plenty of tension pulling it back in again,Confused now, I'll crack on in the morning now, cheers. The vaccuum hose connected ok and not leaking? And you just have the single hose looped from actuator to turbo? Edited June 26, 2013 by WallaceGlanza Quote
liamg40 Posted June 26, 2013 Author Posted June 26, 2013 The vaccuum hose connected ok and not leaking? And you just have the single hose looped from actuator to turbo?Yes mate, single loop from actuator to turbo, it's leading me to think the actuator is faulty now because it's behaving exactly the same with vacuum hose connected or not connected. Quote
liamg40 Posted June 26, 2013 Author Posted June 26, 2013 use this guide, see what happens https://home.comcast.net/~ronald_miranda/hksactuator.pdfCheers for that mate, but that link just shows you how to set the boost and install the actuator which I am already familiar with, It's looking like it's a faulty actuator, I'll know in the morning g when I put the old one back on.Cheers. Quote
liamg40 Posted June 27, 2013 Author Posted June 27, 2013 Just checked the tension on the standard actuator and there is a massive difference between the two!The hks arm is a lot harder to pull out! At least three times harder than the standard one,It's seems quite obvious that this is my problem, Will it be ok to douse it in wd40 a few times? I'm assuming it will be but I'd rather be certain incase I ruin it by not doing my research, Cheers. Quote
akyakapotter Posted June 27, 2013 Posted June 27, 2013 Hks one should be harder to pull out bud Quote
liamg40 Posted June 27, 2013 Author Posted June 27, 2013 Hks one should be harder to pull out bud Oh right, I'm baffled again now, I'm gonna double check everything now and put the old one back on and see what happens,Cheers mate. Quote
5T4R7ET N/A Posted June 27, 2013 Posted June 27, 2013 when you are putting the HKS actuator on, there should be tension on the actuator arm ( pre-load) when putting the actuator arm on the wastegate pin, it should be pretty hard as you have to pull the actuator arm across to put it on the pin. put a picture of the HKS actuator at the setting you have 0.8 bar after installment. might have some vacuum lines mixed up or something Quote
liamg40 Posted June 27, 2013 Author Posted June 27, 2013 when you are putting the HKS actuator on, there should be tension on the actuator arm ( pre-load) when putting the actuator arm on the wastegate pin, it should be pretty hard as you have to pull the actuator arm across to put it on the pin. put a picture of the HKS actuator at the setting you have 0.8 bar after installment. might have some vacuum lines mixed up or somethingYeah that's how it felt when I installed it the first time at 123mm, pretty hard to pull it over on to the pin.But anyway I've just put the standard one back on and it's straight back to the way it was before,I'm back to a steady 0.65, it's not rising or dropping at all on full boost so it's got to be a faulty actuator.Gutted I'm all ready to turn the boost up now for more power! Anyone got a working pin type actuator for sale? Quote
mikey4410 Posted June 27, 2013 Posted June 27, 2013 Makesure actuator working ok by connecting it up to a foot pump or similar with q guage on it and give it a small pump.maybe bladder inside has hole in.... Quote
liamg40 Posted June 27, 2013 Author Posted June 27, 2013 Makesure actuator working ok by connecting it up to a foot pump or similar with q guage on it and give it a small pump.maybe bladder inside has hole in....I haven't got anything g around me at the moment to do that, I'm gonna get another one I think and try that,Cheers. Quote
