Browner Posted July 9, 2013 Posted July 9, 2013 ITEM: High Performance ORC Ogura Racing Clutch & Lightweight Flywheel KitCONDITION: Excellent. Working perfectly. Very little use... Still loads of meat left on the clutch as can be seen in the pictures. EXTRA INFO: ORC Ogura ORC309 Performance racing clutch and lightweight flywheel kit are rated to applications of 400bhp+. Excellent driveability for daily driving in addition to having excellent engine response with the matching lightweight chromoly flywheel supplied. Ready to fit. These retail at over £900 brand new!PRICE: £450LOCATION: Dublin, IrelandDELIVERY TERMS: Courier, post, collection or can meetCONTACT INFO: PM Browner or contact Conor on (00353) 86 378 4399PICTURE:
TurboTobz Posted July 9, 2013 Posted July 9, 2013 Might be worth mentioning of you have the release bearing or not pal. Glwts best clutch I've ever expirienced
Browner Posted July 9, 2013 Author Posted July 9, 2013 Using a second hand release bearing is never recommended mate. Although I think I may have it...
TurboTobz Posted July 9, 2013 Posted July 9, 2013 I know, but they cost around £100 from rhd Japan mate and from what I understand they're specific ones not oem
MARC MOSS Posted July 9, 2013 Posted July 9, 2013 They are specific, great clutch I missed mine badly after the friction plate gave out... They're so expensive to rebuild. It's in shortys 85 now Glwts dude
Broony Posted July 9, 2013 Posted July 9, 2013 i found out the release bearing for these are a nissan part i have the number somewhere think its cheaper than rhdjapan and standard bearings also work with this too
Browner Posted July 9, 2013 Author Posted July 9, 2013 I have another one here exact same just the disc is worn out if anyone fancies replacing the disc or using the kit for spares???
WallaceGlanza Posted July 10, 2013 Posted July 10, 2013 i found out the release bearing for these are a nissan part i have the number somewhere think its cheaper than rhdjapan and standard bearings also work with this too Yeah I'm running my Blitz one with the standard bearing... but it may have just started making a bit of noise, it wasn't a new one I fitted though.
DevonGT Posted August 26, 2013 Posted August 26, 2013 Can you use the standard release bearing with this or not?
dj-rix Posted August 26, 2013 Posted August 26, 2013 No standard bearing will not work correctly, Orc bearing is a lot thicker.
Broony Posted August 26, 2013 Posted August 26, 2013 No standard bearing will not work correctly, Orc bearing is a lot thicker. erm i think you find it does and will
WallaceGlanza Posted August 27, 2013 Posted August 27, 2013 erm i think you find it does and will x 2 The bearings are different but I had no problem with the standard one.
Bluebear Posted August 28, 2013 Posted August 28, 2013 (edited) I tried a standard with mine and it was miles off touching the clutch, as soon as I put in the Ogura bearing it was fine. It's a strange one, I've heard a lot of people say standards are fine and then some say (including my own experience), that the Ogura one was needed. Were the release bearing forks ever different between gearboxes? Surprised this clutch hasn't sold yet either way! Edited August 28, 2013 by Bluebear
Browner Posted August 29, 2013 Author Posted August 29, 2013 Just so lads are aware it was a standard release bearing in the car when this clutch was removed
Bluebear Posted August 29, 2013 Posted August 29, 2013 Just so lads are aware it was a standard release bearing in the car when this clutch was removed Sorry mate, I had no intention of shitting over your sale! Just musing on it that's all. Love mine haha
