will keep u guys posted,cheers tobz,,also i do have a fault apparantley,no ecu light on at all but if i do a diag check i have a knock sensor still.
will look into this obviously aswell
You'd be surprised it made a lot of difference without mine on, afrs were all over the shot
I've heard a few people running without a lambda sensor with no issues what so ever and the ecu still fueling spot on.
when you are driving along at low speed, and put the car in a high gear and floor it, does the afr go round towards lean?
update,brand new lambda sensor fitted up.
cold air fuel still low 10s
warm idle 11.5 and 11.6
i am at the stage now were i am out of ideas.i know these cars well and yet i dont understand whats wrong with my fueling
i dont use the car at all atm as i dont wana cause any damage.somebody please help me try and work this out
the only fault code i have atm is knock sensor......
Edited by mikey4410
ok i will do this next for sure,will put the standard fuel regulator ba on.im sure the fueling wasnt right with this either
thing is though i turned the new sard down from 48 psi to 34 psi and the a/f ratio stayed the same.
surely the engines ecu should be regulating and controlling the a/f wether the fuelings at 48 or 34 psi ?
i have also undone the plus terminal on battery and left it for an hour.
i had a new one in there but thats a fair comment ,will put the new one back in.
the new one i put in recently was removed for a mate to test and i havent put it back in.
will put it back in tonight.thanks
will keep updated.....
What AFR gauge you using? if its not changing atal whatever you do could be the sensor for that. also, checked your still on standard injectors if its so rich?
Ok,fitted new ecu temp sensor and nothing changed.
Had a chat with a mate and he suggests map sensor.
I have done a wanted post and hope somebody can help
Is there anyway to test map sensor at all ??
SORTED !!!!!!!!!!!!!!
I HAVE BOUGHT A MT ECU FROM JAYC GLANZA AND FITTED IT UP AND ALL MY PROBLEMS HAVE DISSAPEARED INCLUDING THE KNOCK SENSOR !!!!!
SO HAPPY AND SO GRATEFULL FOR JAYC FOR HELPING AND TAKING TIME TO SORT THIS WITH ME
