When hot my glanza seems to take a while to start and sometimes idles weird and cuts out my forts are fuel pump as I've got td04 on it atm with 0.5bar of boost any one else had this? Before td04 swap it would fire instantly and when cold it does
the standard ecu fuels fine with 0.5 bar on td04 so the problem could be plugs? you running iridiums?
does it drive fine? any hesitation or jerking at low rpm?
It's got fuel pressure reg as well to help with fuelling, the car drives fines boost fine screams fine dumps fine but just cranks for about 10seconds to start instead of 2 seconds and idles low till I drive it, I do have iridium plugs in it, I know it's probs due a service but only started doin it since td04 swap which baffles me
Have the spark plugs been replaced recently? It's one symptom of tired plugs.
Not for awhile last time they went down it misfired like mad that was about February time actually so may need changing , I will whip them out in the morning and take a look at them
My also does this occasionally and I've got about 4 month old iridiums in there, could using the wrong heat grade cause it?? Would like to know what's causing it tbh.
Proper ennoying ain't it it mine use to start 1st attempt now takes ages when hot
What heat range inrifiums do you have in ?? Personally IMO inridiums ate dog shite iev had nothing but problems with em in every car iev put em in either use standard ngk or put some denso plugs in :)
Ied take em out buddy and put some standard ones in I'm pretty confident it will cure your problem
I'm gonna change them tomos and then see what happens then
standard plugs are the way forward, put em back ! lol
i remember i used to have agro with iridium plug on my old honda xr400 motorbike which is what it came with.
had starting agro ,changed for new standard plug and sorted all problems.
you dont need a fuel pressure regulator on a td04 with 0.5 bar the standard ecu will fuel fine just been lean on spool.
if the plugs are not the problem the next thing I would change would be the FPR.
It's fine now been testing it all night and works and starts fine and the fpr was brand new from td plus I have the fpr as its getting mapped up etc soon
Edited by Glanza-Ben
So your all sorted now then mate??
It seems to be alright for now and starts fine etc the plugs were worn so hopefully it stays alright now
