motion Posted August 8, 2013 Posted August 8, 2013 i know the leaderboard but as above....i am not sure if the result is right furthermore i dont know the weight of my starlet what i dont understand is the big difference betwen the hp at the fly and the wheel Quote
morgey Posted August 8, 2013 Posted August 8, 2013 Mines the same, think I got about 44hp difference. Just go with it its only a rough guide Quote
Socks Posted August 8, 2013 Posted August 8, 2013 ok but still have do find out the weight Just put in the stock weight for now... which is 920kg... Can always update at a later date mate! Quote
motion Posted August 8, 2013 Posted August 8, 2013 (edited) The total weight, specified in the vehicle documentation is 830kgdont know if ist right but it is definitly the lightest Version of ep91 without power steer, climate, clock or something else Edited August 8, 2013 by motion Quote
ryan lang Posted August 8, 2013 Posted August 8, 2013 You lose power through frictional forces and momentum changes in the transmission so the fly figure is always going to be higher than the wheel figureSo is it 110 at the fly?And that's with quite a bit of work too. The biggest difference maker in power was the ecu i imagine? Quote
motion Posted August 8, 2013 Posted August 8, 2013 yes 110 at the fly i dont know what brought the most hp but the biggest WOOOOHOOOO effect came fist time after changing tb and intake manifold second WOOOHOOOHOOO after changing flywheel and gearbox ...it felt like Quote
morgey Posted August 8, 2013 Posted August 8, 2013 The total weight, specified in the vehicle documentation is 830kgdont know if ist right but it is definitly the lightest Version of ep91 without power steer, climate, clock or something else I cant see it being that light from stock. I thought ep91's bottomed out 860-880kgs ishSaying that mines 940kgs with fuel and a 4age so maybe it is possible the 'dry' weight being that low? Quote
motion Posted August 8, 2013 Posted August 8, 2013 as far as i know EP91 N/A weights from 830 kg - 920 kg Quote
motion Posted August 12, 2013 Posted August 12, 2013 (edited) today i was on a scalehere is the evidence with a nearly full fueltank and a hand full of tools unfortunately it weights in 10kg steps should i Change the weight on the leaderboard or is that ok? I have put in 830kg Edited August 12, 2013 by motion Quote
