jake44 Posted August 7, 2013 Posted August 7, 2013 evening all, one of my braided water lines has split. has anybody got one they aren't using? I will replace them all when I next go to my dads but I just need one to get me through till then cheers
Fizturbo Posted August 7, 2013 Posted August 7, 2013 (edited) You could loop it for now,it won't do it no harm.Before evryone goes blah blah blah,i don't run water line on my tdo4 set up an its been fine for years... Edited August 7, 2013 by Fizturbo
jake44 Posted August 8, 2013 Author Posted August 8, 2013 loop it? am I being silly not understanding what you mean?
Chesh Posted August 8, 2013 Posted August 8, 2013 loop the turbo water pipes back, i been running mine for years without water lines
Phil Posted August 8, 2013 Posted August 8, 2013 loop the turbo water pipes back, i been running mine for years without water lines x2 arguably better for the engine. Phil
jake44 Posted August 8, 2013 Author Posted August 8, 2013 do I need to plug the turbo end? and loop them back into each other?
TrisK Posted August 8, 2013 Posted August 8, 2013 do I need to plug the turbo end? and loop them back into each other?Nope Turbo side goes to air, just loop the block
