Is there any differences in sensors etc?
I heard that the sensors on the thermostat housing were different.
Also is there any other differences I should be looking out for?
The actual bare engine is the same, just the thermostat housing sensors i think. Use the MK1 housing.
I had the same issue when i put a 98 spec in a GT.
Thermo housing and some on the inlet are different in some cases. Just swap some of the sensors from your old engine
Ah nice one lads I'll compare the 2 housings if I can get some pics. I did hear they were different just wasn't 100% sure
