EP-Azz Posted August 11, 2013 Share Posted August 11, 2013 Hey lads, as most of ya know I'm td04'd now and because its rotated the nipple on the turbo where the boost controller pipe goes is touching against the radiator , no chance of gettin a pipe on because the rad will be pushing on it so will split can you not just turn the nipple ? Ill get a pic to show you all but its the only problem I've got and all will be well, thanks a lot !! Quote Link to post Share on other sites
iamlegend Posted August 11, 2013 Share Posted August 11, 2013 Civic rad ftw Quote Link to post Share on other sites
EP-Azz Posted August 11, 2013 Author Share Posted August 11, 2013 this is the nipple ...... Ill be getting one eventually legend but not right now !. Quote Link to post Share on other sites
Glanza-Ben Posted August 11, 2013 Share Posted August 11, 2013 this is the nipple ......Ill be getting one eventually legend but not right now !.In that picture there's loads of room Quote Link to post Share on other sites
RobSR Posted August 11, 2013 Share Posted August 11, 2013 Pretty sure you can just twist em round seeing as they pull out. Quote Link to post Share on other sites
EP-Azz Posted August 11, 2013 Author Share Posted August 11, 2013 this is the nipple ...... Ill be getting one eventually legend but not right now !. That's because the rad isn't in on that pic yet haha just so everyone could see what I ment n I hope you can just turn it ? Quote Link to post Share on other sites
Liam_D Posted August 11, 2013 Share Posted August 11, 2013 You cant just turn it, try and turn it and it'll snap off and then you're fucked. Cant you undo the the circlip and rotate the housing away from the rad?? Funny how its catching, as i run the same rad/Turbo set up as you and the same Intercooler in fact and mines no where near? Quote Link to post Share on other sites
EP-Azz Posted August 11, 2013 Author Share Posted August 11, 2013 What circlip lee ? And maybe my turbo is a bit bigger on the cold side housing or something ? Or my rad don't sit the best or something......can ya get a pic of what you mean But if I rotate the hosting then ill have to mod my intercooler pipe again !!? Quote Link to post Share on other sites
EP-Azz Posted August 11, 2013 Author Share Posted August 11, 2013 Only needs moving about a cm that's it Quote Link to post Share on other sites
RobSR Posted August 11, 2013 Share Posted August 11, 2013 You cant just turn it, try and turn it and it'll snap off and then you're fucked. Cant you undo the the circlip and rotate the housing away from the rad?? Funny how its catching, as i run the same rad/Turbo set up as you and the same Intercooler in fact and mines no where near? hmm, one ive had you could, maybe it was already screwed lol Quote Link to post Share on other sites
EP-Azz Posted August 11, 2013 Author Share Posted August 11, 2013 I dno man looks like it might turn but don't wanna fuck it, surely thwres something I can do ! Quote Link to post Share on other sites
Liam_D Posted August 11, 2013 Share Posted August 11, 2013 Some are screwed in Rob, most TD04s are like stuck onto the compressor covers and then when you try and bend them at a different angle they snap. The amount of times i do it at work is silly Azz - the circlip that holds the compressor cover on, just get some snipe nosed pliers and remove the circlip and re angle the compressor cover then re tighten the circlip. Looking at your picture our turbos are the exact same buddy. You should be okay with the intercooler piping if you only need to move it a tiny amount. Quote Link to post Share on other sites
EP-Azz Posted August 11, 2013 Author Share Posted August 11, 2013 Ye ill ask my dad about doing that but will I have enough room to do that with the rad still on ? N should I try to turn it first with a little effort to see if it moves Quote Link to post Share on other sites
RobSR Posted August 11, 2013 Share Posted August 11, 2013 (edited) or just cut the bend off and have it straight? Bit pike but thatll work also Edited August 11, 2013 by RobSR Quote Link to post Share on other sites
EP-Azz Posted August 11, 2013 Author Share Posted August 11, 2013 Ye that could work ? Quote Link to post Share on other sites
RobSR Posted August 11, 2013 Share Posted August 11, 2013 Could do that in the mean time with a little hose clip / cable tie on there. would work fine. Quote Link to post Share on other sites
EP-Azz Posted August 11, 2013 Author Share Posted August 11, 2013 You reckon ? Quote Link to post Share on other sites
EP-Azz Posted August 11, 2013 Author Share Posted August 11, 2013 What about heating the nipple up n bending it while its soft? Quote Link to post Share on other sites
dangeestarlet Posted August 11, 2013 Share Posted August 11, 2013 It will snap, can't you just make brackets to move radiator? Or civic rad? Quote Link to post Share on other sites
EP-Azz Posted August 11, 2013 Author Share Posted August 11, 2013 I dunno .... I do want a civic rad but the bottom hose gets in way of screamer and there expensive , all I've gotta do is get this nipple moved, I could bend the fins in on the rad where its touching to give me room to get a pipe on n then put reflective tape on the rad Quote Link to post Share on other sites
har-vey Posted August 11, 2013 Share Posted August 11, 2013 I would cut it and mount on straight if you have the space Quote Link to post Share on other sites
EP-Azz Posted August 11, 2013 Author Share Posted August 11, 2013 Cut what the nipple ? So there wouldn't be a bend ? Quote Link to post Share on other sites
RobSR Posted August 11, 2013 Share Posted August 11, 2013 (edited) Just chop the bend off lol. Then when youve got time, take the housing off and have it tapped properly with an AN- fitting. Itll work in the meantime. Edited August 11, 2013 by RobSR Quote Link to post Share on other sites
EP-Azz Posted August 12, 2013 Author Share Posted August 12, 2013 Ye well Im cut as little as possible enit Quote Link to post Share on other sites
