(NAS) starlet ep82 Posted August 18, 2013 Posted August 18, 2013 Hi As above some of u may know i'v jus done a big engine build including fittting HEL brake linesSo 1 month of trying to get brake pressure &. We have no brakes at allJust fitted a 2nd hand master cylinder & brake servo & still have no brakes at allBasically thres no brake pressure even after a few pumps& when i start the car up pedal jus goes straight down to the floor Thres no leaks anywhere on all the pipe connections etcI'm actually losing the faith now I have had the servo & master changed of a running carServo n master was changed from a ABS glanzaBut my car is a GT ep82 with no ABSWe had the both rear calipers changed from another car n these calipers are in perfect working orderWen we bleed the brakes its only the both rear brakes that have a more of a fizz rather than air bubblesThere are no leaks at all anywhereAs my friend presses the foot brake i can hear a air noise from near the master/servo is this normal?Also as we press the brakes we can hear fluid at the rear brakes rushing around the pipes& brake pedal gets hard after a few pumps then if i let go of it for 2 sec's it goes right down to the floor then I have had the servo & master changed of a running carServo n master was changed from a ABS glanzaBut my car is a GT ep82 with no ABSWe had the both rear calipers changed from another car n these calipers are in perfect working orderWen we bleed the brakes its only the both rear brakes that have a more of a fizz rather than air bubblesThere are no leaks at all anywhereAs my friend presses the foot brake i can hear a air noise from near the master/servo is this normal?Also as we press the brakes we can hear fluid at the rear brakes rushing around the pipes& brake pedal gets hard after a few pumps then if i let go of it for 2 sec's it goes right down to the floor then I have had the servo & master changed of a running carServo n master was changed from a ABS glanzaBut my car is a GT ep82 with no ABSWe had the both rear calipers changed from another car n these calipers are in perfect working orderWen we bleed the brakes its only the both rear brakes that have a more of a fizz rather than air bubblesThere are no leaks at all anywhereAs my friend presses the foot brake i can hear a air noise from near the master/servo is this normal?Also as we press the brakes we can hear fluid at the rear brakes rushing around the pipes& brake pedal gets hard after a few pumps then if i let go of it for 2 sec's it goes right down to the floor then I have had the servo & master changed of a running carServo n master was changed from a ABS glanzaBut my car is a GT ep82 with no ABSWe had the both rear calipers changed from another car n these calipers are in perfect working orderWen we bleed the brakes its only the both rear brakes that have a more of a fizz rather than air bubblesThere are no leaks at all anywhereAs my friend presses the foot brake i can hear a air noise from near the master/servo is this normal?Also as we press the brakes we can hear fluid at the rear brakes rushing around the pipes& brake pedal gets hard after a few pumps then if i let go of it for 2 sec's it goes right down to the floor then Quote
TurboTobz Posted August 18, 2013 Posted August 18, 2013 Edit that post removing the silly highlighting and reposts first, it's really hard to read that shit lol Quote
(NAS) starlet ep82 Posted August 18, 2013 Author Posted August 18, 2013 hi have'nt been on here in ages & not quite sure how to edit that format i copied n pasted my write up from another forum! sorry for the layout guys Quote
kavan-k Posted August 18, 2013 Posted August 18, 2013 You need to bleed them again laddy, fizzing, hearing fluid moving about the pipes and hearing air.... Defo bleed them again! Quote
(NAS) starlet ep82 Posted August 18, 2013 Author Posted August 18, 2013 hi we have already tried the easy bleeder it's a actually my friends car parked at my unit (johnnygt) hes only signed up on tgtt.com also we fitted hel braided lines all round & we had a look at MY ep82 & every line etc is fitted on correctly we have bled them several times now master cylinder & brake servo was changed too we've spend nearly 3 weeks at my unit trying to get some brake pressure but its never gonna happen he's actually starting to hate the car now this is very very strange tho as i've done brakes before on other cars without any problems Quote
(NAS) starlet ep82 Posted August 18, 2013 Author Posted August 18, 2013 the only air we can hear is from near the servo vacuum hose it's also a new vacuum hose too as we press the pedal down we can hear air coming from near the servo but this might be normal i think ??? really stuck with this now been well over weeks surely someone must have come across the same problem this ?? what would be the next step ?? Quote
Amjad Posted August 18, 2013 Posted August 18, 2013 Seen a similar problem on a mate's car before, MS replaced after front brakes were binding. Then new MS and the pedal was dropping. Swapped another servo on and it works now. Servo you're using might be faulty or damaged Quote
(NAS) starlet ep82 Posted August 19, 2013 Author Posted August 19, 2013 Thanks amjad for the infoI think we maybe gettin another servo n mastee cylinder from a running car lets hope this fixes itAny more input on this guys anything else it can be ?? Quote
1991 starlet owner Posted August 20, 2013 Posted August 20, 2013 Not being funny, but you've checked you have enough brake fluid??? Quote
Addymk2 Posted August 20, 2013 Posted August 20, 2013 Again not being funny, you sure you've fitted the servo/master cylinder the right way around? Quote
(NAS) starlet ep82 Posted August 24, 2013 Author Posted August 24, 2013 thanks guys everything was fitted the right way around we changed the master cylinder again on HIS car & finally we have some brakes pedals bit down tho BUT also the rear passenger side caliper on his car is dragging the car back all a sudden & this is after we refitted the calipers back on the car &the new brake master cylinder but yeah we have some brakes finally & the caliper that is dragging back was totally fine last week help :/ cheers! Quote
