This is from a glanza s I broke, the glanza s ecu is setup to work alongside the corolla inlet and you can run the glanza s injectors which I belive are slightly larger, against my mates sr the glanza s was much quicker acceleration and higher top speed.
No its not the same. Glanza s ecu is different to the ukdm and gi. Imo probably mostly for fuel. the only gain would be your wallet will be lighter to keep down that power to weight ratio....
