Fuelling problem
Hiya guys
Now when boosting over 0.5 bar of boost my car starts stuttering and feels like I'm hittin 5 bricks walls
I know this isn't right
When I bought the car I was its because I need to set up my apexi safc 2 ? But I have no clue
Anyone help me ?
I would take that apexi out for now you won't need it just yet if your running stock boost clean those spark plugs check the dizzy cap look at all the basics first imo
I would do this, the reason it's jolting is because its trying to go past 0.85 boost, this is when fuel is cut to protect the engine. Turn boost down.
Edited by Sefton-EP91
Nope all they do is raise or lower the voltage at certain rpm points. Plus they need a 0-5v sensor reading from the tps as it has a high and a low ''map'' if you want to call it that. Our starlets do not use a 0-5v sensor for the tps unless you have a auto tps. Hence why the emb doesnt have the grey (i think) tps wire wired in.
