anti lift kit fitted today what a difference can carry much more speed through corners on very greasy roads it feels like it isnt understeering as much what a difference
minted bro, your car must handle like a leech now,
is there anything you dont like about your setup now?
not really mate it feels like a different car now i wanted to lower it but it would be purely for looks i couldnt see it making it corner any quicker.
yes a complete pig to get off had to use a bit of heat luckily freind works at toyota done it there on a ramp wouldnt like to do it on my back on the floor but other than that quite simple to fit
Broke the link between the anti roll bar and the lower control arm, so need new ones - on both sides!
so car's gonna be off the road until I get a replacement for them B)
i believe whiteline do anti lift castor kits (www.whiteline.com.au)
this kit increases the caster angles of the front wheels and alters the angle of the front lower control arm, inducin an anti lift effect
havnt a clue how much they go for though!
eric
unit equip used to do just the anti-lift kit too. its just a plate of metal 10mm thick with 2 holes in! stops the car shifting so high under acceleration, the whiteline one alters the castor connection to the side, so makes it handle better.
