Spoon_tuned Posted September 7, 2013 Posted September 7, 2013 Think my crank seal is leaking got oil around that area and everywhere underneath my wheel arch is it just a case of pulley off remove seal and replace??? Quote
tatep82 Posted September 7, 2013 Posted September 7, 2013 I would like no know this too as I rekon my crank seal has gone too! Quote
garreth27 Posted September 7, 2013 Posted September 7, 2013 also have to take the cambelt off and remove the cam gear from the crankshaft. Might as well replace the cambelt, idler and tensioner as well if it hasnt been done recently. Quote
AdamB Posted September 7, 2013 Posted September 7, 2013 As above! Remove aux belts, remove crank pulley (may need a puller), remove bottom timing belt cover, remove the crank gear and replace the seal.You would also be mad not to replace the oil pump seal as well, or even change the entire oil pump assembly whilst your at it. Quote
Spoon_tuned Posted September 7, 2013 Author Posted September 7, 2013 Its being done at toyota on tuesday im getting a price on having the cambelt done too as i have a brand new cambelt kit in my shed. Quote
Matt1878 Posted September 7, 2013 Posted September 7, 2013 I would like no know this too as I rekon my crank seal has gone too!Crank seal was all good on that when you bought it dude.. I wouldn't worry too much. The engine bay needed a huge clean especially the underside Quote
maddox710 Posted September 8, 2013 Posted September 8, 2013 Good to hear that you've got the glanza aiden Quote
