Im in the middle of doing this with my 4paw, decided to turbo that N/a engine.
Parts list i'm using from a GT.
Looms
ECU
Clocks
MAP sensor
Dizzy setup
Oil filter housing and bolt
PAS pump and hose
Coil and ignitor
Thermostat housing
Inlet manifold
Throttle body
TPS
Ignition leads
Injectors
Modded sump, or a turbo and oil pick-up sump for yours
Turbo kit
Intercooler
I believe the FPR, pump and rail are the same.
Think thats about it :)
Buy a GT engine with all the bits, + map sensor, dizzy, ignitor, coil, gt ecu, and engine loom. Splice engine loom into the n/a. They are very similar.
mine runs a 1n(which is no faster than a bicycle pushed by lance armstrong without snorting coke!)
i intended to swap a 5efe. I don't want turbo, I'm not after aweseome power, just some fun on the road. Was looking at 140-150ish from a 5efe
Mistakingly, i bought a 5afe instead(they look almost identical, other than identical cc and bhp) and 5efe's are somewhat hard to find. on the other hand the 4 is quite common. What do you think of
-rebore block
-polish, port and skimming cylinder head
-1.4vvti inlet manifold
4-2-1 exhaust manifold
-wide exhaust
