Callumcat Posted November 2, 2013 Posted November 2, 2013 Blitz EBC and Power Meter Dual SolenoidTuning Developments high flow fuel pump NGK Spark Plugs fitted FMIC and custom pipework fitted JAM Racing ECU running TD04 @ 1Bar 238.9BhpTD04 Turbo fitted Wepr four branch manifold with external wastegateTial External Wastegate with 1Bar SpringScreamer PipeAlloy Civic RadCone Air Filter with custom intake front mountedAircon removedSuspension and ExhaustBC Racing Coilovers fittedPolyflex Engine Mounts fittedPolyFlex Exhaust Mounts BlueFlame full stainless Steel ExhaustBrakes and TransmissionCusco Brake Master Cylinder Stopper fillHel braided brake linesTuning Developments fast road brake kit (Greenstuff Front pads and grooved front discs inc race brake fluid) Spec Race Clutch Have turned down the gain and boost on the ebc for daily as it's mapped so is a animal when it's off and running 240 What do I do to turn Down the boost or what is safe please help new to this Quote
Glanza Mac Posted November 2, 2013 Posted November 2, 2013 you cant turn it down, you need to get a 0.6 or a 0.8 bar spring for your wastegate and also an electronic boost controller to be able to turn the boost back up again to 1.0 bar when you need it Rob. Quote
Azz Posted November 2, 2013 Posted November 2, 2013 As above, you can only run the spring pressure or higher not below.1 bar spring = 1-1.4bar 0.7bar spring = 0.7-1.1And so on all ran through the ebc Quote
Callumcat Posted November 2, 2013 Author Posted November 2, 2013 So when my ebc is off that's why it's always 1 bar because of the spring I have In my waste gate??Or can I just turn it down with the ebc I have Sorry for being a pain And is 1 bar safe daily or will it cause problems Quote
Callumcat Posted November 2, 2013 Author Posted November 2, 2013 I get it lads sorry it's late and not thinking correctly I see the fact that I have the ebc makes no difference because of the spring I have in my waste gate, got the gain on 15 and boost at 10 using the ebc and is a lot less crazy is this safe or should I go and get a smaller springJust want it reliable sorry for all the questions I'm new as you can tell Quote
TrisK Posted November 2, 2013 Posted November 2, 2013 You shouldn't have a gain higher than the duty cycle. But apart from that sounds fine Quote
Callumcat Posted November 2, 2013 Author Posted November 2, 2013 (edited) What the gain should be less than boost?And is it worth getting a smaller spring to be a safe bet? just got it and want to make sure tbh Edited November 2, 2013 by Callumcat Quote
RobSR Posted November 3, 2013 Posted November 3, 2013 (edited) The gain/settings are totally different for every car.. 1bar td04 is fine, but if your feeling worried, yea buy a .8 bar spring. Edited November 3, 2013 by RobSR Quote
mindless Posted November 3, 2013 Posted November 3, 2013 1 bar everyday should be fine. You won't be reaching 1 bar 100% of the time unless you drive like a madman every single time you go out with the car. You should be able to keep it off max boost with a little discipline. Quote
Chris_GlanzaV98 Posted November 3, 2013 Posted November 3, 2013 Get a decent ecu in there and have it mappwd and it should be fine Quote
Callumcat Posted November 3, 2013 Author Posted November 3, 2013 Yea it's mapped useing jam racing ecu so should be fine?? have sorted it out for daily use using the ebc much more useable now Thinking about getting a turbo timer anybody recommend any?? Quote
Chris_GlanzaV98 Posted November 3, 2013 Posted November 3, 2013 Well if its a plug and play im not 100% mate but on emanage setup on a dyno should defo be safe, get a hold of a few guages and keep an eye on afr's etc Quote
Callumcat Posted November 3, 2013 Author Posted November 3, 2013 Brought it off here so hopefully should be setup correctlyWas dynoed at Colchester power station so may of been mapped there Quote
