LooNy Posted November 11, 2013 Posted November 11, 2013 Brought a engine with gearbox complete.Cannot bleed clutch. The peddle for to the floor with no resistance but releases to original position on its own. I've got fluid up to the slave cylinder.Now I've ran out of ideas ffs Quote
TrisK Posted November 11, 2013 Posted November 11, 2013 Could be the slave at faultOr could be clutch fork not engaged. Or could just need bleeding more. They do take a while to get firm in my experience Quote
akyakapotter Posted November 11, 2013 Posted November 11, 2013 They do take a while to get firm in my experienceHaha Quote
LooNy Posted November 11, 2013 Author Posted November 11, 2013 No dirty talk please aha lolI have swapped slave with my one that I know works and still nothing and there's fluid in coming out when I crack the but off going in the slave but nothing out the bleed nipple Quote
Ryan_EP82 GT Posted November 11, 2013 Posted November 11, 2013 (edited) Did you fill the reservoir to the brim with fluid first? Is there a method where you keep the nipple closed and pump the pedal 5 times, hold it down to the floor and then you can open the valve and bleed out the air, close the valve and pull the clutch pedal back up from the floor..and repeating the process until you get a proper clutch feel? Edited November 11, 2013 by Ryan_EP82 GT Quote
