Bulb out most likely. Easy to replace, lower the steering wheel, few trims and the dial surround off with a couple of screws, 10mm bolt, pull clocks as far forward as you can, hand round the back, pull out speedo cable and a few multiplugs and then the clocks will be out. Take the bulb down to the motor factors, think its a T4 or something but i cannot be 100% sure.
  • 6 months later...
Digging up a old thread here
But are the bulbs coloured or is there a filter?
I wish to keep the green but brighten the speedo up with leds
Could you simply pop in white t4 bulbs!
