russ78 Posted February 12, 2014 Author Share Posted February 12, 2014 bump Link to post Share on other sites
russ78 Posted February 14, 2014 Author Share Posted February 14, 2014 bump Link to post Share on other sites
russ78 Posted February 17, 2014 Author Share Posted February 17, 2014 bump Link to post Share on other sites
russ78 Posted February 18, 2014 Author Share Posted February 18, 2014 ttt Link to post Share on other sites
russ78 Posted February 20, 2014 Author Share Posted February 20, 2014 bump Link to post Share on other sites
russ78 Posted February 21, 2014 Author Share Posted February 21, 2014 ttt Link to post Share on other sites
russ78 Posted February 21, 2014 Author Share Posted February 21, 2014 bump Link to post Share on other sites
russ78 Posted February 22, 2014 Author Share Posted February 22, 2014 bump Link to post Share on other sites
russ78 Posted February 23, 2014 Author Share Posted February 23, 2014 ttt Link to post Share on other sites
russ78 Posted February 28, 2014 Author Share Posted February 28, 2014 bump Link to post Share on other sites
russ78 Posted March 16, 2014 Author Share Posted March 16, 2014 bump Link to post Share on other sites
MARC MOSS Posted March 16, 2014 Share Posted March 16, 2014 I'd give up mate lol Link to post Share on other sites
russ78 Posted March 16, 2014 Author Share Posted March 16, 2014 its because not many people realise what it actually does Link to post Share on other sites
whitestar Posted March 18, 2014 Share Posted March 18, 2014 Are you sure it needs FCD too when boosting an NA? Link to post Share on other sites
russ78 Posted March 18, 2014 Author Share Posted March 18, 2014 Are you sure it needs FCD too when boosting an NA? yes bud one alters air/fuel mix and the other stops you hitting fuel cut, it is caveman tuning but essentially will get you boosting Link to post Share on other sites
rmsnoel Posted March 22, 2014 Share Posted March 22, 2014 Whats the wire you cut to do away with fuelcut, the yanks do it alot? Link to post Share on other sites
dangeestarlet Posted March 22, 2014 Share Posted March 22, 2014 So you could use this to boost an n/a with the standard n/a ecu? Link to post Share on other sites
russ78 Posted March 22, 2014 Author Share Posted March 22, 2014 So you could use this to boost an n/a with the standard n/a ecu? it is possible yes but would need a FCD and a wideband to set it up correctly Link to post Share on other sites
dangeestarlet Posted March 22, 2014 Share Posted March 22, 2014 Ok il have a look into this and might have it if I can find enough info about it Link to post Share on other sites
Steven1995 Posted March 27, 2014 Share Posted March 27, 2014 I don't get it how it works. I thought the N/As didn't even have a fuel cut The only problem is the N/A's ECU can't handle boost, only vacuum. Link to post Share on other sites
Matts Posted March 27, 2014 Share Posted March 27, 2014 its because not many people realise what it actually does The HKS AFR is a fuel-adjustment device that regulates the air/fuel ratio by changing the airflow voltage output to the vehicles factory computer. The AFR was designed for vehicles that are lightly tuned (intake, exhaust system, etc.) and need only slight fuel adjustment. The 12 setting adjustment indicator allows the user to enrich or lean the stock fuel settings by approximately 1.0 A/R point in either direction (richer or leaner). Link to post Share on other sites
david_chantry Posted March 28, 2014 Share Posted March 28, 2014 Still got this mate? Link to post Share on other sites
dangeestarlet Posted March 28, 2014 Share Posted March 28, 2014 Yes he still has it Link to post Share on other sites
russ78 Posted April 15, 2014 Author Share Posted April 15, 2014 SOLD Link to post Share on other sites
