turbo Grant Posted November 25, 2013 Posted November 25, 2013 Sounds like you have air in the system. Check to see if you still have cluch fluid and look for leaks on the slave and master Quote
smb2011 Posted November 25, 2013 Author Posted November 25, 2013 Its 1.1/2 cm below max on the fuild Quote
turbo Grant Posted November 25, 2013 Posted November 25, 2013 Pop the rubber boot off see if it's all wet behind it. And stick your head under the dash see if it's leaking inside the car Quote
smb2011 Posted December 2, 2013 Author Posted December 2, 2013 Problem is back again no leaks fuild normal hight no leaks on the slave starting to think its the clutch plate Quote
bajansuperman Posted December 3, 2013 Posted December 3, 2013 what color is the fluid if its dark cylinder might need changing Quote
smb2011 Posted December 3, 2013 Author Posted December 3, 2013 Nah its not dark the car is fine at the minute but any minute it will just not go in any gear and sometimes pull away when i havent even lifted the clutch its a weird one Quote
GLANZA-MAN Posted February 18, 2014 Posted February 18, 2014 My car does this did you ever find the problem ? Quote
morgey Posted February 19, 2014 Posted February 19, 2014 Plate fitted wrong way round. Bent clutch forkWrong thrust bearingAdjustment on clutch pedalBleed the clutch lines Quote
