The flanges for this turbo are different to the standard td/vf turbos so would only be able to run this turbo with this manifold if memory serves correct russle may be able to advise better tho
I double checked with zisco and the kit will directly fit any externally gted td05 or td06.
Great bit of kit, the kit will fit externally gated turbos, not your usual TD/IHI/MHI turbos.
all the same you have PM russleh.
Phil
Edited by Philm
As above, it will fit a TD05 14b and maybe an 11b ?
I have seen this in the metal and its some bit of kit, whoever buys it will not be dissatisfied.
I swear there is and old post on TGTT of a very similar kit which went for over 2K, this is some bargain now !!
