Zeldoz Posted December 4, 2013 Posted December 4, 2013 I think i am missing the bolt to attach this to the turbo? See pic below of the oil line, if i am where can i get one? Need it sourced locally or i'll have to order it online. I have no idea on the size.. are they are generic? Bought it from Jamie on here...? Quote
akyakapotter Posted December 4, 2013 Posted December 4, 2013 (edited) I think it's an m10 by 1.5 banjo bolt don't quote me on that though Edited December 4, 2013 by akyakapotter Quote
Zeldoz Posted December 4, 2013 Author Posted December 4, 2013 Sorry bad information. The oil feed line. There is a loop as seen in the pic, Im sure it needs a bolt to attach to the turbo. I doubt it magically holds itself on!! Can i re-use my CT9 oil feed bolt].... Or will i need to buy a new bolt? Quote
TrisK Posted December 4, 2013 Posted December 4, 2013 Sorry bad information. The oil feed line. There is a loop as seen in the pic, Im sure it needs a bolt to attach to the turbo. I doubt it magically holds itself on!! Can i re-use my CT9 oil feed bolt].... Or will i need to buy a new bolt?nope, you need a td04 banjo bolt there might be one in your td04 This should do it, i think http://www.ebay.co.uk/itm/Turbo-Oil-Feed-Banjo-Bolt-Kit-M10x1-5mm-SUBARU-TF035HM-TD04L-TD05H-1-5mm-Hole-/130894465602?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1e79eb0a42 or if not im sure ractech/td/maybe idworkz can supply them Quote
Zeldoz Posted December 4, 2013 Author Posted December 4, 2013 I have asked ben.. But heres is the only pics i got off it, I dont know where the feed is, Can you see it? Quote
Socks Posted December 4, 2013 Posted December 4, 2013 Remember to use copper washers either side of the line on the banjo bolt too! Quote
Ryan_EP82 GT Posted December 4, 2013 Posted December 4, 2013 Sorry bad information. The oil feed line. There is a loop as seen in the pic, Im sure it needs a bolt to attach to the turbo. I doubt it magically holds itself on!! Can i re-use my CT9 oil feed bolt].... Or will i need to buy a new bolt? obviously it isnt magical mate, and i would hardly expect the ct9 banjo to fit if its a tdo4 oil feed. try idrees at id-workz for the banjo there not hard to come across. or look at tdo4 oil feeds with the banjo equipped and try work it out Quote
Zeldoz Posted December 4, 2013 Author Posted December 4, 2013 Spoken to Mike at TD and he doesn't think the oil feed will fit the engine.. i bought it off Jamie so confused... :/ Any else wanna have a look... Mike's said that wont fit the block.. Quote
Jamie_VF22 Posted December 4, 2013 Posted December 4, 2013 Its a TMD oil line i used it for 2 years on my old set up so it does fit , and you need the fitting for the turbo for it to screw on pal Quote
Zeldoz Posted December 4, 2013 Author Posted December 4, 2013 Its a TMD oil line i used it for 2 years on my old set up so it does fit , and you need the fitting for the turbo for it to screw on pal Mike @ TuningDev said it wont fit the block.... O.O He will sell me a banjo bolt but he thinks that wont fit either.. Confused as hell now lol Quote
Zeldoz Posted December 4, 2013 Author Posted December 4, 2013 (edited) Can anyone just confirm if with the banjo bolt it will fit the block? I dont need anything else? Edited December 4, 2013 by Zeldoz Quote
Mikeyallgood85 Posted December 4, 2013 Posted December 4, 2013 Can anyone just confirm if with the banjo bolt it will fit the block? I dont need anything else? just ask Mike for the dimensions of the bolt and compare/measure it against the thread on the block and you will have your answer!! ;-) Quote
Jamie_VF22 Posted December 4, 2013 Posted December 4, 2013 (edited) The ct9 banjo bolt fits that is what i used for 2 years running this line Edited December 4, 2013 by Jamie_VF22 Quote
Zeldoz Posted December 4, 2013 Author Posted December 4, 2013 Im still confused as fook here lol! I dont doubt Jamie hes a top lad. Just need to sort out what else im missing to fit this! Quote
Ryan_EP82 GT Posted December 4, 2013 Posted December 4, 2013 The ct9 banjo bolt fits that is what i used for 2 years running this line did you try it with the ct9 banjo bolt zeldoz? Quote
TurboTobz Posted December 5, 2013 Posted December 5, 2013 (edited) have you got the metal ring for the ewg, sits inside and makes a seal if not you may wanna order one now to save disappointment Edited December 5, 2013 by TurboTobz Quote
Jamie_VF22 Posted December 5, 2013 Posted December 5, 2013 have you got the metal ring for the ewg, sits inside and makes a seal if not you may wanna order one now to save disappointment It does have the metal ring in it pal Quote
Zeldoz Posted December 5, 2013 Author Posted December 5, 2013 Yeah it does.Offered banjo bolt from iddy. I'm away in London until late saturday night. I'll be doing it Sunday if Santa delivered all my parcels. Fingers crossed! Quote
