Am i missing the bolt to attach this to turbo?
I think i am missing the bolt to attach this to the turbo? See pic below of the oil line, if i am where can i get one? Need it sourced locally or i'll have to order it online.
I have no idea on the size.. are they are generic? Bought it from Jamie on here...?
7250A4C9-25BE-4C6E-8224-AD759C178179-738
Sorry bad information.
The oil feed line. There is a loop as seen in the pic, Im sure it needs a bolt to attach to the turbo. I doubt it magically holds itself on!!
Can i re-use my CT9 oil feed bolt].... Or will i need to buy a new bolt?
nope, you need a td04 banjo bolt
there might be one in your td04
This should do it, i think
http://www.ebay.co.uk/itm/Turbo-Oil-Feed-Banjo-Bolt-Kit-M10x1-5mm-SUBARU-TF035HM-TD04L-TD05H-1-5mm-Hole-/130894465602?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1e79eb0a42
or if not im sure ractech/td/maybe idworkz can supply them
obviously it isnt magical mate, and i would hardly expect the ct9 banjo to fit if its a tdo4 oil feed. try idrees at id-workz for the banjo there not hard to come across.
or look at tdo4 oil feeds with the banjo equipped and try work it out
  On 12/4/2013 at 11:31 AM, Jamie_VF22 said:
Its a TMD oil line i used it for 2 years on my old set up so it does fit , and you need the fitting for the turbo for it to screw on pal
Mike @ TuningDev said it wont fit the block.... O.O He will sell me a banjo bolt but he thinks that wont fit either.. Confused as hell now lol
  On 12/4/2013 at 11:59 AM, Zeldoz said:
Can anyone just confirm if with the banjo bolt it will fit the block?
I dont need anything else?
just ask Mike for the dimensions of the bolt and compare/measure it against the thread on the block and you will have your answer!! ;-)
