ep82paul Posted December 12, 2013 Author Posted December 12, 2013 Ye did it cold this morning i tested 1&2 yesterday warm and i got 90 on both so there is some thing wrong any advive please on what to do next as i dont no much about these only had my other about a month n it got written off might buy another motor then i can fix this one Quote
ep82paul Posted December 12, 2013 Author Posted December 12, 2013 Would it make any diffrence if i got engine temp warm then test it Quote
ep82paul Posted December 12, 2013 Author Posted December 12, 2013 Has any one used a sniff tester for checking headgasket or is they any other better way of checking dont whant to pull engine out yet because the car was running mint before this happend no misfires Quote
Russleh Posted December 12, 2013 Posted December 12, 2013 My car sounded like this twice when the piston ringlands went. If you open the oil filler cap and put a white piece of kitchen cloth or rag over it and it gets covered in oil spray then it could be that because of the excess blowby gasses. If its just a little splat here and there id check other stuff before assuming this. Headgasket is also a possible culprit because of the low readings in both cylinders as its unlikely the rings or ringlands went in both. Personally id hope for headgasket as there no pistons and bearings and rings to replace. Hope some of that was useful Russell Quote
ep82paul Posted December 12, 2013 Author Posted December 12, 2013 Ill try that soon as i get home try out hopefully wont have to pull engine out Quote
ep82paul Posted December 13, 2013 Author Posted December 13, 2013 Started the car and took the oil filler cap off and air was blowing out felt like a fan loads of pressure i put a rag there about 20seconds later it looked like this then 10seconds later it looked like this could this mean its the head gasket dont no if this would make any diffrence but oil was flicking all over my front wing Quote
ep82paul Posted December 13, 2013 Author Posted December 13, 2013 Just started it again taken oil cap off again this happend within a second Quote
Turk Posted December 23, 2013 Posted December 23, 2013 I think your ringlands have gone matey. Try having a look at your pistons and you bore through the spark plug hole before you rip your engine apart. Quote
5T4R7ET N/A Posted December 23, 2013 Posted December 23, 2013 If ring land was gone the oil would also come up through the rocker cover breather. The one on the left side. Quote
ep82paul Posted December 23, 2013 Author Posted December 23, 2013 Ye mate cheers i stuck a inspection camara down to look at the cylinder bores and tops of the pistons couldent see any thing wrong just orded headgasket kit timimg belt and headbolts hopefully thats my problem so i dont have to strip motor Quote
