Anybody had any issues with the ignition timing on there gt or glanza???
I think mines off as its idling high jerky when backing off the gas it jerks and it idles high when at junctions etc
Ive bled the radiator and checked all vacuum hoses and replaced gaskets
Remove the intercooler pipe from the throttle body and you'll see a circle shaped hole inside. Block that off with your finger and see if it helps? I've had this problem with a few of my Starlets.
if that helps do i need to replace the tb??
No mate, just check and double check all the vacuums on the throttle body. I removed the vacuum hoses and refitted them, that sorted it the last time I tried.
Ive checked all pipes they all look good mate...
Mine looked absolutely fine mate, try blocking that hole off and see what happens mate.
What will it mean if you block the hole and it runs okay?
