Who uses these tyres 195/50/15 on there Starlets? My glanza is ready for a pair of tyres and I've wanted these for ages so gonna replace all for and get the alignment fast road set up again.
What I want to know is, do you have any arch rubbing issues? And what size width wheels? Alignment settings are you guys running. Just don't wanna spend £300 for something to catch the arches at every opportunity.
Cheers
Liam
I've got them on my car. 195/50/15. At a guess 6.5j around a 35-40mm offset.
Had a bit of rubbing to start with, raised it 5-10mm on my bc's and it was fine on about mid way soft-hard.
Now running 0.5 deg 6 clicks from soft on the front 4 from soft on the rear and about 22psi IIRC. Absolutely no rubbing what so ever. With no arch rolling at all... However the wheels do need spacing out to look good imo!
This is how it sits height wise, could do with raising the rear a tad I think.
Edited by morgey
thinking of getting these tyres next better reviews that the toyo r1rs. they have : a rating in the wet. so cant be bad.
I've used R1Rs they are good but don't last long at all. Have a look at nankang ns2r good reviews on them might try some next
  • 3 months later...
