Malcolm GT Posted January 20, 2014 Posted January 20, 2014 I'm finding now that my windscreen is iced on the inside. It normally get moisture on it and obviously freezing.Anything I can do to prevent this. I will check the under back seat gromits but this is a joke. Can't be scraping ice off the outside and then the inside too!! Quote
JayJ Posted January 20, 2014 Posted January 20, 2014 Clean your windows and if you have matts, dry them, check that you haven't activated recirc mode on heater control. Remove your ventilator cowl and check that it's not blocked or wet inside. You can also buy air dehumidier/moisture removers from ebay/stores. :-) Quote
LukeSR Posted January 20, 2014 Posted January 20, 2014 Most of the time its just condensation that has frozen.. Even my Corolla does it. Quote
morgey Posted January 20, 2014 Posted January 20, 2014 Change your pollen filter as well. Mine was soaked so that kept causing it to mist up. Quote
