Lambda sensor wire snapped!!!
My Lambda sensor wire has snapped on the wiring loom side,
My plan is to splice the 2 wires together and not use the connectors, but i need an extra bit of wire to connect both wires together,
what type of wire can I use as a substitute for lambda sensor wire?
Yes! this guy is a legend! ^^^ was thinking about a kind of alternate connector as i'm always taking my decat on/off etc, but thought a blue splice connector would be the easiest option, but spades would be a lot better, cheers mate :)
Edited by scottieboi94
  • 2 months later...
