Connorhoggg Posted January 21, 2014 Posted January 21, 2014 i have a 38mm external waste gate and i have no idea if this is a stupid question or not but how do i make the dump stupidly loud ? Quote
Chris_GlanzaV98 Posted January 21, 2014 Posted January 21, 2014 You cant make a wastegate louder the dump as is loud as it is The wastegate doesnt dump, your dump valve does, unless the flange is blocked of the noise is the air going back through the turbo ! Maybe do a bit of reading into it and get clued up Quote
Connorhoggg Posted January 21, 2014 Author Posted January 21, 2014 You cant make a wastegate louder the dump as is loud as it isThe wastegate doesnt dump, your dump valve does, unless the flange is blocked of the noise is the air going back through the turbo !Maybe do a bit of reading into it and get clued up okay Quote
RM15_Glanza Posted April 22, 2014 Posted April 22, 2014 You cant make a wastegate louder the dump as is loud as it isThe wastegate doesnt dump, your dump valve does, unless the flange is blocked of the noise is the air going back through the turbo !Maybe do a bit of reading into it and get clued up Technically an External waste gate does 'dump' its just we in the UK don't really use that term its more a yank thing lol an external gate dumps to atmosphere, I know you can change the note of the waste gate by varying the length and shape of the screamer pipe also weather its thick walled steel too, i custom made my screamer pipe to the same shape as the down pipe and it sounds a lot deeper than any other screamer I've heard..... go on my instagram and have a look at a couple videos of mine n you'll see instagram name is: twistedsymmetry Quote
Amjad Posted April 22, 2014 Posted April 22, 2014 LOL Dan you took the words straight out of my mouth Quote
