dangeestarlet Posted February 5, 2014 Posted February 5, 2014 Read a few guides of leaving the cap off but it doesn't seem to want to bleed , put a new thermostat in it today and it still won't do it, it's not smoking like if the head gasket is gone or nothing , thanks in advance Quote
TrisK Posted February 5, 2014 Posted February 5, 2014 Rad cap offHeaters on full and hotThen leave to idle up until full operating temp Quote
dangeestarlet Posted February 5, 2014 Author Posted February 5, 2014 Done that it keeps spilling out of radiator Quote
Jamie5414 Posted February 5, 2014 Posted February 5, 2014 Squeeze both the bottom and top rad pipes at the same time too? Quote
dangeestarlet Posted February 5, 2014 Author Posted February 5, 2014 Yep they all seem warm aswell , doing my head in now I've had enough lol Quote
Chris_GlanzaV98 Posted February 5, 2014 Posted February 5, 2014 Put the cap on start the car and go forward and back for a min see if it disloges any air bubbles make sure the car is cool before the cap is taken back off Quote
Jamie5414 Posted February 5, 2014 Posted February 5, 2014 Yeah that seems like the next best thing to do, I had to go around the block and up a hill to dislodge a air bubble in a Peugeot 306 lol Quote
yaristurbo Posted February 5, 2014 Posted February 5, 2014 Ash's glanza needed a quick run to bleed heater matrix Quote
daniel_g Posted February 5, 2014 Posted February 5, 2014 Can also hold the revs at about 2.5k or there abouts using the throttle cable, and squeeze hoses at the same time. Quote
dangeestarlet Posted February 5, 2014 Author Posted February 5, 2014 Just won't work and to top it off my heaters won't switch on! That's all there is with this car is problems grrrr Quote
Chris_GlanzaV98 Posted February 5, 2014 Posted February 5, 2014 bleed it and do it again if you have more coolant mate, or better still catch the coolant and put it back in Quote
daniel_g Posted February 5, 2014 Posted February 5, 2014 Try leaving it overnight with the cap off and see if its easier tomorrow, some air might find its way out as the system settles. In work if they wont bleed i always take them a quick run and 9/10 times it works. Quote
yaristurbo Posted February 5, 2014 Posted February 5, 2014 Feel water pipes going to heater matrix Quote
dangeestarlet Posted February 5, 2014 Author Posted February 5, 2014 Il keep trying to bleed it , the 2 Heater matrix pipes are hot Quote
