I've just swapped the new engine from 1 Glanza into another Glanza and all is well apart from two plugs on thermostat housing which ain't there on my old one which had one plug any one had this before
Was it a GT engine in the Glanza ? I know there are a few different housings used on starlets.
I had this when putting a 98 spec engine in a GT.
Just swap the full thermostat housing over.
Not a clue mate there just both glanzas I don't know the history of the engines, I don't have the old housing from mine
The 96 and 98 spec Are different I no the water tempt sensors on the thermo housing are different but not see what else on the engine side
It's only the thermostat housing that's giving me the trouble
From memory the later 98 spec has an oval plug which costs a fortune and the 96 didn't. If you have a look on camskills am sure they list both new with pictures and you can see if its the 98 spec one your have
There's two plugs the I don't have on thermostat housing my loom has a oval ish shape but the housing has a different shape and a spade connector sensor
Is the oval ish shape plug green? Im sure the coolant temp sensors are different are they not?
No the green one is plugged in its just this one plug left on my loom but as said the new engine has a different shape sensor and another sensor like a spade connector next to it
The looms also pass through the firewall differently...
Facelift ep91 - Goes thru top right hand side...
Pre-Facelift ep91 - Go through under inlet AND top right hand side...
Fusebox's are also different...
The Looms are very different!
Yep :( glad I'm getting old housing back
