Glanza looms different
Was it a GT engine in the Glanza ? I know there are a few different housings used on starlets.
I had this when putting a 98 spec engine in a GT.
Just swap the full thermostat housing over.
Not a clue mate there just both glanzas I don't know the history of the engines, I don't have the old housing from mine
Is the oval ish shape plug green? Im sure the coolant temp sensors are different are they not?
No the green one is plugged in its just this one plug left on my loom but as said the new engine has a different shape sensor and another sensor like a spade connector next to it
The looms also pass through the firewall differently...
Facelift ep91 - Goes thru top right hand side...
Pre-Facelift ep91 - Go through under inlet AND top right hand side...
Fusebox's are also different...
The Looms are very different!
Yep :( glad I'm getting old housing back
