fordie_glanzaV Posted February 8, 2014 Posted February 8, 2014 Brought 2nd hand lsd box from a lad on tgtt My mate has just started stripping it. And 5th gear will come off the shaft.He's removed the circlips and got his gear puller on it but still not moving..anyone had this problem before and got a solution? Any help will b much appriciated. Lewis Quote
morgey Posted February 8, 2014 Posted February 8, 2014 Which kind of puller is he using? The arm type ones?My mate made a wedge type gear separator. 2 tapered plates with tube on either end and bolts going through then you just do the bolts up and it pulls together and lifts the gear off the shaft.Bit like this http://www.harborfreight.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/i/m/image_18479.jpg?01AD=3jiKXLQhA61ZgSuxe5WrPAzNZi9WpC5-kF1rxEiRwX9jlFwB4Lx25HA&01RI=C572B0883225251&01NA= Quote
TurboTobz Posted February 8, 2014 Posted February 8, 2014 I'm sure I have seen 5th being a b#$tard to remove before and ending in tears Quote
yaristurbo Posted February 8, 2014 Posted February 8, 2014 Think mine was 50 from toyota split in half way well stuck on Quote
daniel_g Posted February 8, 2014 Posted February 8, 2014 I snapped a few teeth of 5th before lol. Quote
fordie_glanzaV Posted February 8, 2014 Author Posted February 8, 2014 Im not sure what puller he is using as i havent been down to see it yet.He stoppes in at my work earlia just to let me know.Said he gunna try abit of heat on monday.. Theres also a small chip on the tooth is that gunna cause problems if he does get it off Think mine was 50 from toyota split in half way well stuck onThe gear was only 50 from toyota?? Quote
fordie_glanzaV Posted February 8, 2014 Author Posted February 8, 2014 Aint to bad then. I deal with toyota through work so get stuff at trade price plus discount..Ill look into it monday.Thanks mate. Quote
