Did you clean your cooler and pipes from oil? If yes, then you probably got another leaking turbo
Yeah I cleaned out the hot pipe, intercooler pipes etc with break cleaner. Was told the turbos oil seals are brand new as well so I'm not sure what the problem is
Turbo seals are brand new in that turbo, did you clean exhaust out? From previous turbo failure? And have you checked Pcv valve if your still running one?
it's Ok now I took off the hot pipe, revd the engine for a good 5 minutes all the old oil came out.
Thanks alot
Just alittle advice when I get mine back please what's the best way to get the the oil in the fmic and pipes out and anywhere else it should be sitting?
Get some break cleaner, spray it into the pipes. It cleans out every bit of oil
