Jay85 Posted February 22, 2014 Posted February 22, 2014 Just picked up my gt 😄Driving home the temp gauge went thought the roof!! Pulled over and the fan wasn't running, put the heaters on full heat and temp started to drop! No smoke, runs smooth and has plenty of water in it! Any ideas?? Quote
Chops Posted February 22, 2014 Posted February 22, 2014 (edited) broken thermostat? my mates mx5 did exactly this a week ago, thermostat imploded and was stuck nearly shut all the time. good place to start. be careful not to overtighten the two bolts holding it on, they sheer really easily, as i found out when i did mine Edited February 22, 2014 by Chops Quote
Socks Posted February 22, 2014 Posted February 22, 2014 Air Lock/Thermostat Broken or block may cause the overheating... However the fan should come on... Test the fan by running 12v directly to it. If the fan runs , there is a fault with the wiring! Quote
Jay85 Posted February 22, 2014 Author Posted February 22, 2014 Bottom tad hose is warm not too hot to hold! 😞 How would I tell if it's an airlock/blockage?? Quote
Jay85 Posted February 22, 2014 Author Posted February 22, 2014 Yes mate, I know the seller he's not pulled a fast one or anything! He's been driving about in it for the last few months! Quote
Jay85 Posted February 23, 2014 Author Posted February 23, 2014 Ok so not managed to change the thermostat but went for a drive and she was fine, started a bit more spirited drive and up the temp gauge went, pulled over and had a snoop. The rad was really hot apart from the passenger side which was only warmish!! Any further ideas?? Quote
Chops Posted February 23, 2014 Posted February 23, 2014 i still think the thermostats probably jammed half open, or theres a blockage in the system somewhere. id start with the thermostat, and while the coolants out get the rad out, have a look at it and flush it through mate. Quote
Jay85 Posted February 23, 2014 Author Posted February 23, 2014 Thank you mr chops!! Guess I just keep running clean water through till it flows with ease?? Quote
Chops Posted February 23, 2014 Posted February 23, 2014 lol just realised i didnt read your post properly, sorry. a friend of mines starlet had a load of crap in its standard rad, flushing it through the opposite way to normal flow managed to dislodge it. chunks of old whatever might come out the intake if it is blocked. Quote
Jay85 Posted February 23, 2014 Author Posted February 23, 2014 No worries thank you for the advice!! And Mr socks of course Quote
Jay85 Posted February 24, 2014 Author Posted February 24, 2014 Ok, thermostat changed and rad flushed! Still the same problem!Starts up and warms up fine, will sit at idle and be fine, normal driving fine, give it a boot and up the temp goes! It will then continue to over hear with normal driving! Can keep it cool using the heaters on full! Help 😢 Quote
Taggy Posted February 24, 2014 Posted February 24, 2014 (edited) I think if its over heating isn't that a classic sign of HG failure? particularly if you drive more spirited. Go to a garage and get the radiator sniff tested. They will be able to measure if exhaust gasses are getting into your coolant system. I think if super heated gasses from the cylinders is leaking into the water jacket is causes havoc with the cooling system. Easy test and they will give you an answer straight away. Just ring around if they can do one in your local garage. Edited February 24, 2014 by Taggy Quote
Jay85 Posted February 24, 2014 Author Posted February 24, 2014 Cheers for the advice! It's gonna be poo if it's the head gasket! Quote
Taggy Posted February 24, 2014 Posted February 24, 2014 (edited) yeah it will be a pain, luckily changing the HG on starlets though isn't a difficult job and you could do it your self on a weekend if you haven't done it before. If it has failed though, always remember to get your head skimmed to ensure its totally flat, its about £30 in a machine shop, worth doing for peace of mind and while the head is off its probably worth getting your valve stem seals changed too as the parts are only cheap and will prevent any future problems while its apart Edited February 24, 2014 by Taggy Quote
Jay85 Posted February 24, 2014 Author Posted February 24, 2014 Would of thought that it would over heat all the time tho!! Quote
Jay85 Posted February 24, 2014 Author Posted February 24, 2014 Also if I turn the car off and leave the ignition on the temp gauge takes ages to drop like 3mm in 45 mins 😤 Quote
Taggy Posted February 24, 2014 Posted February 24, 2014 Ah right ok if the temp gauge isnt budging after 45 mins when you turn it off its likely to be a dodgy temp sender then, as your right thats not normal lol. Change the sender, i think they are less than a tenner. Quote
Taggy Posted February 24, 2014 Posted February 24, 2014 this is the one your after, under the dizzy https://www.google.co.uk/search?q=starlet+temperature+sender&tbm=isch&imgil=48nrYdZLqoB1YM%253A%253Bhttps%253A%252F%252Fencrypted-tbn3.gstatic.com%252Fimages%253Fq%253Dtbn%253AANd9GcTAmujAT1NDJeovfyDfXw_J14jw8bEElrmPfSrsH3U1lB14rMiv%253B203%253B400%253BZjb6CIFSbMJwrM%253Bhttp%25253A%25252F%25252Fwww.camskill.co.uk%25252Fm19b0s1301p48340%25252FToyota_Starlet_Turbo_%252525255BEP82_EP91%252525255D_-_Parts_Spares_Tuning_Servicing_Accessories_-_Engine_Coolant_Temperature_Sender_-_Starlet_Turbo_up_to_05_1997&source=iu&usg=__Obsak5Kj1QyQ5-t65GFN2qpOOtc%3D&sa=X&ei=Ys4LU_aFJYvg7QaPg4GIBw&ved=0CFIQ9QEwAg&biw=1680&bih=949#facrc=_&imgdii=_&imgrc=48nrYdZLqoB1YM%253A%3BZjb6CIFSbMJwrM%3Bhttp%253A%252F%252Fwww.camskill.co.uk%252Fsmsimg%252F225%252F43317.3177.gif%3Bhttp%253A%252F%252Fwww.camskill.co.uk%252Fm19b0s1301p48340%252FToyota_Starlet_Turbo_%25255BEP82_EP91%25255D_-_Parts_Spares_Tuning_Servicing_Accessories_-_Engine_Coolant_Temperature_Sender_-_Starlet_Turbo_up_to_05_1997%3B203%3B400 Quote
Jay85 Posted February 24, 2014 Author Posted February 24, 2014 Just went for a drive and it spewed a load of coolant out the top of the rad could it be the rad cap?? Quote
Jay85 Posted February 25, 2014 Author Posted February 25, 2014 Can of petrol and a box of matches could be on the horizon!! Lol Quote
BIGGFOOT Posted February 25, 2014 Posted February 25, 2014 ^LOL^ don't do that just get a dual core civic radiator and change thermostat should cure it Quote
Jay85 Posted February 25, 2014 Author Posted February 25, 2014 Changed the thermostat and flushed the rad, must be another cause!! Found out the rad cap wasn't secured properly!! Back to the drawing board Quote
