monty1991 Posted February 22, 2014 Share Posted February 22, 2014 not sure to be disappointed or not, 1 bar ct9zep ecuported manizisco decatHKS cat back tuner said shes fueling great and running well. checked compression last night and got 150psi over all 4 cylinders so i'm guessing shes pretty healthy what you guys think?? Quote Link to post Share on other sites
Phil Posted February 22, 2014 Share Posted February 22, 2014 170hp grand job. good compressiongood fueland running decent AFRs? nothing to worry about. certainly no HP you could easily find with ZEP ecu. Seems a healthy result to me. Phil Quote Link to post Share on other sites
Chris_GlanzaV98 Posted February 22, 2014 Share Posted February 22, 2014 again everything looks fine to me, wouldnt be to disshartened numbers mean nothing its how it feels on the road Quote Link to post Share on other sites
D3N0 Posted February 22, 2014 Share Posted February 22, 2014 Are you still running the top mounted intercooler? Quote Link to post Share on other sites
Taggy Posted February 22, 2014 Share Posted February 22, 2014 stick your result up on the leader board Quote Link to post Share on other sites
maddox710 Posted February 22, 2014 Share Posted February 22, 2014 Good result I bet it's a blast to drive on the fast spooling ct Quote Link to post Share on other sites
monty1991 Posted February 22, 2014 Author Share Posted February 22, 2014 On 2/22/2014 at 8:02 PM, D3N0 said: Are you still running the top mounted intercooler? Nah Front mount with short hot pipe! On 2/22/2014 at 8:46 PM, maddox710 said: Good result I bet it's a blast to drive on the fast spooling ct its not to bad although shes bein lying up the past few months, dont take her out in bad weather, found an apexi power fc for good money so gonna try sell the zep, and get a custom map for the car! Quote Link to post Share on other sites
starletburkie Posted February 22, 2014 Share Posted February 22, 2014 Seems good to me nice and rich up top for the ct9 too! Realistic ct9 figures Quote Link to post Share on other sites
Greenmachine81 Posted February 22, 2014 Share Posted February 22, 2014 Good result lad.. u happy with that figure? Quote Link to post Share on other sites
Gainzy Posted February 23, 2014 Share Posted February 23, 2014 Not a bad result at all some 2ltr cars don't even run that...no matter how much power you have there is always somebody else running more the other map will get abit more out the engine Quote Link to post Share on other sites
monty1991 Posted February 23, 2014 Author Share Posted February 23, 2014 On 2/22/2014 at 10:12 PM, Greenmachine81 said: Good result lad.. u happy with that figure? Would av liked a wee bit more for braggin rights lol i'm just happy shes running good and its a healthy engine On 2/23/2014 at 11:23 AM, Gainzy said: Not a bad result at all some 2ltr cars don't even run that...no matter how much power you have there is always somebody else running more the other map will get abit more out the engine Thats true, give most cars a suprise, yh if the zep sells i'll def buy the apexi means it will suit any setup in the future! Quote Link to post Share on other sites
Taggy Posted February 23, 2014 Share Posted February 23, 2014 (edited) Looking at the figures i reckon you could easily add another 15hp+ by adding a boost controller which can be adjusted to the rev range, boost pressure tends to tail off as you go up the rev range. You can see you made peak power at about 6800-6900 Rpm, yet your boost pressure has dropped from a max of about 1.08 down to 0.92. If you setup your boost controller to add more boost (gain) at that rev range you can level out the boost pressure curve and increase your HP Edited February 23, 2014 by Taggy Quote Link to post Share on other sites
monty1991 Posted February 23, 2014 Author Share Posted February 23, 2014 do ya recommend any? ive a greddy profec b spec 2 but never use it. Quote Link to post Share on other sites
callum tgtt Posted March 14, 2014 Share Posted March 14, 2014 150 across all 4? Ticking time bomb Quote Link to post Share on other sites
DevonGT Posted March 14, 2014 Share Posted March 14, 2014 On 3/14/2014 at 8:48 AM, callum tgtt said: 150 across all 4? Ticking time bomb Not sure what your referring to, but that's a good figure. Quote Link to post Share on other sites
gorganl2000 Posted March 17, 2014 Share Posted March 17, 2014 very good and realistic figure for your set up. i'd say enjoy the car and i'd keep the zep for now, as it seems to be working fine with what you have do you have an adjustable actuator? Quote Link to post Share on other sites
