  • Replies 110
  • Created
  • Last Reply
Top Posters In This Topic
on with painting the rocker cover, got some magnacore leads and a proper timing belt covers as was using 4e ones on the 5e
oh and think ive found a box :)
  • 1 month later...
  • 3 weeks later...
ok this could be a good check list
build gearbox and fit
buy and install injectors
drive shafts
come up with fuel system
finish race spec rocker
get my head around wiring for engine
gt track rod ends
intercooler and piping
mount radiator
mapping
theres probably more...
Few bits to do. You can use the ep70 track rods and ends on the 82 hubs. That's what I'm running. With the fuel system you have a few options. Ditch all the oem stuff and fit a race cell with built in pump. Or fit an electronic lift pump that feeds a swirl tank then that feeds the high pressure injection pump. The 2 simplest ways of doing that.
Intercooler and rad fitting is fun! Not much room after engine and turbo kit are in!
In the fuse box you have a blanked off efi fuse space. Remove the blank and pop and female spade terminal in the back and you have a fuse efi power source that's what I wired my main efi relay up to.
  • 1 month later...
Thought about this thread other day so update is in order, forged 5e is out and for sale and I got the rwd 4age out and test fitted
With a few days planning and measuring and figuring out the steering rack set up it was a plan
Pulled it to bits and started fresh
I have the little aw11 for a running engine with loom
Sorted a inlet manifold and propshaft
Got a axle and 4 link set up
Should be all systems go
A couple of picks for mocking up and fabrication started
Blocks are interchangable between heads.
They do about 4 different blocks and 4 different heads iirc
3 rib. Very early bigport tvis engines 40mm main journals. (Everything after these were 42mm)
7 rib later bigport tvis engines. (87ish to 90)
7 rib small port non tvis (has oil squirters under pistons) 90-92ish
7 rib 20v. Sump has different bolt pattern to 16v all 20v have oil squirters.
Then you get the 4agze but they use the same block as the year they were produced but have different internals.
Edited by morgey
Yes afaik. 8 bolt cranks on all.
There is 2 different clutch sizes though. Earlier are 200mm which I think 86's use and from smallport onwards had 212mm clutches. Not sure if the f/wheels are interchangable between fwd and rwd platforms though.
Yeh friction should be. Almost any toyota 212mm friction plate should work.
but I dont know if the rwd flywheels are deeper or anything or if you could use the later 212mm f/w from a post 90 4age.
I think your main task atm is getting it in and running then worry about thar stuff later lol
