Is it only under throttle or at high speeds aswell? If its at high speeds and you drop clutch does it disappear. And if its under throttle does it do it if you just rev the engine while in neutral?
Sounds absolutely horrid on video. You would get a whine from the release bearing in neutral if it was that. I'd be tempted to jack the front up stick it on axle stands and bang it in 1st get someone to accelerate while you try pinpoint were the noise is coming from
could it be the CV joint? mine clicks when I'm just cruising and that is the cause, and it went away and came back too....best way is do what was said above, get her on stands and go underneath with someone accelerating in gear
took it to a garage and its a knackered cv joint. Both the inner and outer boots have tears. The garage recommend replacing the whole driveshaft is this necessary or will replacing the outer cv joint fix the issue?
Do GT Turbo Shafts fit a glanza? I think im going just swap the driveshaft as both boots were knackered and chance the inner joint may not be healthy
Just replace the whole shaft. If you're taking it to a shop to have the work done, by the time you pay for all the parts, new boots, labour, etc you'd probably be spending that much anyways.
i can get two shafts from a gt for £60 so most likely going to do that. My fear is the spline count may be out and i'll be left with no car for another week
  • 4 weeks later...
i have the same problem mate. when i accelerate i get a horrible friction noise as if somethings scraping or rubbing! did you pinpoint what this was? was it the cv joints in the end? thanks
