On the brake fluid cap on my glanza it says use only dot3 fluid so why are some people using 5.1? O bought 5.1 but unsure weather it's safe to use!
It's fine mate but you need to completely empty the system then fill it up with 5.1. Basically Dot 3 is the minimum fluid to use.
They could of put that on the cap would of made life easier lol thanks homeslice
Toyota dot 5.1 is pretty decent.
I have about 40'000 bottles of Mintex dot 4 which i 'get free' from work, which is just as good as the Toyota stuff tbh.
