Gainzy Posted March 4, 2014 Share Posted March 4, 2014 On the brake fluid cap on my glanza it says use only dot3 fluid so why are some people using 5.1? O bought 5.1 but unsure weather it's safe to use! Quote Link to post Share on other sites
Nick85 Posted March 4, 2014 Share Posted March 4, 2014 It's fine mate but you need to completely empty the system then fill it up with 5.1. Basically Dot 3 is the minimum fluid to use. Quote Link to post Share on other sites
Gainzy Posted March 4, 2014 Author Share Posted March 4, 2014 It's fine mate but you need to completely empty the system then fill it up with 5.1. Basically Dot 3 is the minimum fluid to use.They could of put that on the cap would of made life easier lol thanks homeslice Quote Link to post Share on other sites
Jamie5414 Posted March 4, 2014 Share Posted March 4, 2014 May as well use DOT4, That can handle higher temperature if you have uprated brakes too. Motul 600rbf Quote Link to post Share on other sites
daniel_g Posted March 4, 2014 Share Posted March 4, 2014 Toyota dot 5.1 is pretty decent. I have about 40'000 bottles of Mintex dot 4 which i 'get free' from work, which is just as good as the Toyota stuff tbh. Quote Link to post Share on other sites
Manny Posted March 5, 2014 Share Posted March 5, 2014 Daniel you serious? That's a lot lot lot. Quote Link to post Share on other sites
daniel_g Posted March 5, 2014 Share Posted March 5, 2014 Daniel you serious? That's a lot lot lot.Not quite 40'000 no.. Quote Link to post Share on other sites
