Dusty Posted March 8, 2014 Share Posted March 8, 2014 So decided to fit my hks plug and play ecu got 3 plugs in but left with 3 smaller plugs and a long cable cuming from the ecu with a round 3 pin plug not sure where any of them go, this pic may help, can also get a pic of the other circle plug Any help appreciated cheers Quote Link to post Share on other sites
dangeestarlet Posted March 8, 2014 Share Posted March 8, 2014 Pretty sure your standard ecu plugs into them and the hks is a piggy back Quote Link to post Share on other sites
Dusty Posted March 8, 2014 Author Share Posted March 8, 2014 On 3/8/2014 at 8:34 PM, dangeestarlet said: Pretty sure your standard ecu plugs into them and the hks is a piggy backSo I plug them into the standerd one?What about the circular 3 pin socket? Where would it go? Quote Link to post Share on other sites
Dusty Posted March 8, 2014 Author Share Posted March 8, 2014 Just went out and got it plugged in cheers Just got this circular 3 pin plug witha good meter of cable, There's a FCD can I just unplug the 2 joints and cut the other two wires and thatl be it obv make sure there no bits o wire showing anywhere. Quote Link to post Share on other sites
Dusty Posted March 8, 2014 Author Share Posted March 8, 2014 Looking for a home for this wee guy Quote Link to post Share on other sites
TrisK Posted March 8, 2014 Share Posted March 8, 2014 What does the actual Ecu look like?I think that plug is for a hks map sensor Quote Link to post Share on other sites
Dusty Posted March 8, 2014 Author Share Posted March 8, 2014 (edited) On 3/8/2014 at 9:46 PM, TrisK said: What does the actual Ecu look like?I think that plug is for a hks map sensorThere a black box that was plugged into standerd ecu on its got denso 1 sticker what's this?Do I need a separate HKS map sensor?The guy I bought it from told me it was a straight fit as he just took it out of his Edited March 8, 2014 by Dusty Quote Link to post Share on other sites
Gainzy Posted March 8, 2014 Share Posted March 8, 2014 Sure there is more to it you need, seen one on ebay hmm Quote Link to post Share on other sites
Dusty Posted March 8, 2014 Author Share Posted March 8, 2014 On 3/8/2014 at 10:26 PM, Gainzy said: Sure there is more to it you need, seen one on ebay hmmU got a link mate? Quote Link to post Share on other sites
Gainzy Posted March 8, 2014 Share Posted March 8, 2014 Look up hks ecu I can't get link on my phone at the min I don't believe the guy it's a piggy back not simple plug n play you will need that mapped I'm sure of it! Quote Link to post Share on other sites
Gainzy Posted March 8, 2014 Share Posted March 8, 2014 I guarantee you it's not all there if he has just taken it out of his he has assumed to you it's working but you can't get it functioning the way it should be without the rest! I would try get my cash back if I was you without the sensor etc it's no use... Quote Link to post Share on other sites
TrisK Posted March 8, 2014 Share Posted March 8, 2014 Same Ecu as I have in my gt. It's a piggyback fuel controller. Old school thing. Works though. There's several bits to it. The Ecu, a fcd, and a seperate map sensor You need it all for it to work Quote Link to post Share on other sites
Dusty Posted March 8, 2014 Author Share Posted March 8, 2014 On 3/8/2014 at 10:52 PM, TrisK said: Same Ecu as I have in my gt. It's a piggyback fuel controller. Old school thing. Works though. There's several bits to it. The Ecu, a fcd, and a seperate map sensor You need it all for it to workSo will it do anything atall for me? How much they worth?Just bought a TD04 was hoping to run it with this until I get emanage blueWill have a look for hks map sensor This was there when I took the glove box out is it standard? Quote Link to post Share on other sites
TrisK Posted March 8, 2014 Share Posted March 8, 2014 I'll try and get to mine and take some photos for you When Marc had my car he ran a td04 on itIt's good and works but I think cause it's old not many tuners have the software or experience with them Quote Link to post Share on other sites
dangeestarlet Posted March 8, 2014 Share Posted March 8, 2014 Yes that's standard mate it's some sort of control box, the hks is a piggy back ecu, I don't know nothing about them but I think they have to be remmaped to suit your setup, you should of bought a p&p like jam etc , or wait till you go td04 and get emanage blue and get it mapped Quote Link to post Share on other sites
Dusty Posted March 8, 2014 Author Share Posted March 8, 2014 On 3/8/2014 at 11:22 PM, TrisK said: I'll try and get to mine and take some photos for you When Marc had my car he ran a td04 on itIt's good and works but I think cause it's old not many tuners have the software or experience with themSo does it need to be remapped?What kind of money's in them mate? Quote Link to post Share on other sites
dangeestarlet Posted March 8, 2014 Share Posted March 8, 2014 Yes it needs to be remmaped, not much , iirc there was one for sale on here not long dog for like £100-200 but I can't remember Quote Link to post Share on other sites
Dusty Posted March 8, 2014 Author Share Posted March 8, 2014 (edited) On 3/8/2014 at 11:39 PM, dangeestarlet said: Yes it needs to be remmaped, not much , iirc there was one for sale on here not long dog for like £100-200 but I can't rememberGot done over then bought it as a plug and play ecu that was still in his ep91 at the time took it out when it was sold and he was running TD04 , but that was in December so have no chance now payed 300 for it Edited March 8, 2014 by Dusty Quote Link to post Share on other sites
TrisK Posted March 8, 2014 Share Posted March 8, 2014 That's not bad. You can adjust it yourself if you have an afr guageAnd if he was already rubbing a td04 it should only need minimal adjustments Quote Link to post Share on other sites
dangeestarlet Posted March 8, 2014 Share Posted March 8, 2014 Perhaps it's allready been mapped to his td04, so should run your td04 fine , just check Afr's or get it mapped Quote Link to post Share on other sites
Dusty Posted March 8, 2014 Author Share Posted March 8, 2014 (edited) Ok I've mailed him to see about the map sensor, can just unplug it to pass mot on ct9 and try it with the TD04 can I adjust anything with a afr Gauge would it help to get a fpr with a gauge , maybe just sell it and got for emanage blue Edited March 8, 2014 by Dusty Quote Link to post Share on other sites
Phil Posted March 9, 2014 Share Posted March 9, 2014 On 3/8/2014 at 11:47 PM, TrisK said: That's not bad. You can adjust it yourself if you have an afr guage These are great bits of kit for the money. an fcd isnt dear and your set. no software needed for a remap either just 7 seperate settings on a board inside. Phil Quote Link to post Share on other sites
Dusty Posted March 9, 2014 Author Share Posted March 9, 2014 On 3/9/2014 at 12:03 AM, Philm said: These are great bits of kit for the money. an fcd isnt dear and your set. no software needed for a remap either just 7 seperate settings on a board inside. PhilMaybe not so ba after all I have the fcd it's the map sensor I'm missing , how do i adjust the settings on the board? Quote Link to post Share on other sites
Phil Posted March 9, 2014 Share Posted March 9, 2014 cant mind the boost threshold but im not sure you need the specific hks/denso map sensor to run it. to adjust the setting just unscrews the metal cover and you'll see a numbered screw. turn the screw to the desired setting. you must however use a wideband or borrow a wideband to check the fueling is correct. Phil Quote Link to post Share on other sites
Dusty Posted March 9, 2014 Author Share Posted March 9, 2014 (edited) On 3/9/2014 at 12:22 AM, Philm said: cant mind the boost threshold but im not sure you need the specific hks/denso map sensor to run it. to adjust the setting just unscrews the metal cover and you'll see a numbered screw. turn the screw to the desired setting. you must however use a wideband or borrow a wideband to check the fueling is correct. PhilEasy enuff done then what sort of reading would I be looking for on the wideband? Would I just change it till I found one where everything was running at a safe level? Edited March 9, 2014 by Dusty Quote Link to post Share on other sites
