What is the difference between them in performance?
i hv found one which is up for sale.its exhaust flange is rectangular type which is wider than ct9 flange from side.dont know exact way to describe it.its may be t28 flange!
  • 2 weeks later...
The 19t will be a t2 flange in most cases. It also will be very laggy depending on its exhaust housing really but the compressor wheel is much bigger anyway.. It will boost like a small td05
  • 2 months later...
19T refers to the compressor wheel, the usual TD04 that most people use has a 13T compressor wheel.
Flanges are irrelevant as the compressor sides are mostly interchangeable. I'm unsure about it being a T2 flange though, T2 is a Garret and TD04 is MHI.
The difference in performance will be that the 19T wheel is bigger and can run more boost/flow more air.
Edited by ste91
