Hi lads,
Basically cut a long story short I had the RWD GT Turbo out drag racing on Sunday and snapped the passenger side rear half shaft.
Toyota being Toyota, a lot of parts are interchangeable between models. Surely the half shafts are the same as something else? Does anyone know if they will interchange with anything? It's going to be very hard to find a half shaft for one. I am going to try buying new from Toyota today... You never know!
Regards,
Conor.
Ahh man thats shit, i guess that a few Toyotas from that era will have the same setup, all the 4wd corollas and that kinda stuff. EL55 E103 kinda models, although most of them were Jap only like the EP85s.
EP95 stuff might still be available from Toyota, guessing its the same ?
I started doing it
Part 42311-16050 (SHAFT, REAR AXLE) was found on the following models:
Date range Model Frames/Options Found in diagram
12/1989-12/1995 TOYOTA STARLET EP8*,NP80 41-02: REAR AXLE SHAFT & HUB
09/1990-08/1994 TOYOTA CORSA, TERCEL EL4*,NL40 41-02: REAR AXLE SHAFT & HUB
09/1994-06/1999 TOYOTA CORSA, TERCEL EL5*,NL50 41-02: REAR AXLE SHAFT & HUB
09/1990-08/1994 TOYOTA COROLLA 2 EL4*,NL40 41-02: REAR AXLE SHAFT & HUB
09/1994-06/1999 TOYOTA COROLLA 2 EL5*,NL50 41-02: REAR AXLE SHAFT & HUB
Provided i have the right part number
Nice one TrisK, what site is that ?
Knew theyd be the same as the Corollas lol.
PM me Daniel
Yes mate the VIN number is EP850028636
Is that the right part in the diagram above? I think i got the car without the VIN
Yes it looks to be correct. I haven't taken the broken shaft out yet it will probably be a pig to remove. I stripped down the hub and jacked up the car to listen while I turned the wheel and you can hear the broken shaft about 8" inside the wheel.
They are a live axle very similar to the AE86
hello but still thing the ae 86 is not 4*100 it 4* 114 or something, so it will not fit
if you have found something let me please know because i drive a ep95.
thanks
@ ghost 12 - yes the ae86 half shafts are a different hub fitment but I run hub adapters on mine to suit the twincam fitment
  • 2 weeks later...
I took the passenger half shaft out and as I suspected it was broke. Done a nice job of it!
I took the one out of my red ep85 for the time being.
Now my question lads. I went to Toyota with my ep85 vin number and they said the shaft was discontinued... BUT they said the ABS shaft is still available. Will this fit if I knock the ABS ring off? I take it the ABS half shaft is out of the later ep95 are these interchangeable?
Need to get this baby sorted pronto for Japfest UK!
Conor.
