maddox710 Posted April 1, 2014 Posted April 1, 2014 Item For Sale:WEPR ultimate TD/VF turbo kitItem Condition & Description: >>>>>PLEASE READ THIS DISCRIPTION<<<<<<< if you have read my build thread it will give you a good idea to why I am NOT using this.but if you haven't basically the manifolds runner fouls on the clutch slave cylinder pipe.THIS IS STILL A BRAND NEW ITEM!!!!!!was purely mocked up on my engine only to find the problem.im sure there are guys on here that will be able to figure out a way round the problem like bend the pipe and add a heat shield too itPrice:its priced accordingly£375 ono or swap for coiloversPictures:Payment & Shipping Details:ONLY THIS PRICE INCLUDE POSTAGE
Beastmode panda Posted April 1, 2014 Posted April 1, 2014 GLWS Will, I'd personally just get a sanding disc on a grinder and just shave it down a little bit til it clears, then just spray it in matt/satin black again til the heat wears it all off. Simple way round it.
wickedep Posted April 2, 2014 Posted April 2, 2014 guys..if you use 5e slave cylinder..the hose outlet is from the top..it will clear this manifold completely. if you want to use the 4e cylinder..then you can grind it down a bit as RBZ suggested..there's 3.6mm's of thickness to play with good luck with the sale.. sacha
philfrost432 Posted April 2, 2014 Posted April 2, 2014 will you do a swap mate i have a 2 month old zisco ramhorn minifold kit, would come with decat pipe, and screamer pipe, no cracks or repairs still good as new, just like the look of your kit, and wouldnt mind doing some work to make it fit cheers
maddox710 Posted April 2, 2014 Author Posted April 2, 2014 will you do a swap mate i have a 2 month old zisco ramhorn minifold kit, would come with decat pipe, and screamer pipe, no cracks or repairs still good as new, just like the look of your kit, and wouldnt mind doing some work to make it fit cheers No only want cash or coilovers as stated
triple j Posted April 2, 2014 Posted April 2, 2014 Might consider swapping my coilovers, am in ire do.
1990timeismoney Posted April 2, 2014 Posted April 2, 2014 Will this come with the hoses and oil water lines etc
maddox710 Posted April 2, 2014 Author Posted April 2, 2014 Will this come with the hoses and oil water lines etc No as it comes straight from sacha @WEPR it's manifold, 3"downpipe and brace for downpipe
