Hi, I have fully removed my air conditioning and all the air con idle up valve from the left of that black bracket.
I was wondering if I can get rid of this thing too whatever it is or is it part of the idle up valve if so i'll take it off??
Cheers
Nik
strange and purely coincidental.removed all aircon stuff from both gts and glanzas and removed fine with no issues
if your believing what has just been said then just unplug and drive and then u will see it makes no difference of or on,its just idle up parts etc
makeusre u blank any pipes going to inlet etc
Yeah that sounds right mate, I have removed quite a few things from the bay that do't need to be used that use vacuums from the manifold so going to block them all off and hopefully i'll run fine. Re-shelling atm so hopefully it starts up first time!
