Ollieh17 Posted April 6, 2014 Posted April 6, 2014 Getting pretty bored of my setup atm and want a bit more power. I have about £400 to £500 to spend within the next month. My choices are to:buy a td04 setup and run that at low boost while saving for management or:buy a plug and play ecu and run my current ct9 setup at a bar and save for a turbo kit and management and then sell the plug and play If i was to buy a TD04 kit and run that at 0.7bar what will the power be like compared to a ct9 with plug and play be like? Quote
Glanza-Ben Posted April 6, 2014 Posted April 6, 2014 Td04 at 0.8 bar is massive difference to ct9 mate I would never go back to ct9 or even to hybrid Quote
mikey4410 Posted April 6, 2014 Posted April 6, 2014 u can run a td04 at 0.8 bar no issues dude it does go well i can assure you Quote
Ollieh17 Posted April 6, 2014 Author Posted April 6, 2014 sweet!! change of plans then, have a wideband on the way so can keep an eye on things Quote
mikey4410 Posted April 6, 2014 Posted April 6, 2014 yes a wideband is imperative to have on a starlet in my eyes. Quote
Glanza-Ben Posted April 6, 2014 Posted April 6, 2014 Never had a wide band on mine lol but then don't drive it much, 100% go td04 though mate you won't regret it Quote
mikey4410 Posted April 6, 2014 Posted April 6, 2014 yeah td04 is an awesome turbo,cheap to source and reallly do give a great kick Quote
Azz Posted April 6, 2014 Posted April 6, 2014 And you can happily go to a bar without management by running am fcd its not the best but there's plenty of people that run it Quote
ro55ifumi Posted April 7, 2014 Posted April 7, 2014 You will need to ensure that fueling is set up and an FCD is just tricking the set up and definitely not a way i would go. Personally save your money till you can afford the set up that you are wanting to run with the correct mods etc and save on possible heartache. John Quote
TurboTobz Posted April 7, 2014 Posted April 7, 2014 yes a wideband is imperative to have on a starlet in my eyes.seconded Quote
