You need to get innovative with getting the valve clearences correct with regrinds, and make sure they go through some hardnening process and your valve spring base pressures are correct or you'll chew through the lobes in no time at all.
As said Tighe's are the best drop in cam available with a very wide range of specs or go custom. Unless your looking to make 350bhp+ I wouldn't waste your money, everyone seems to get the wrong cam specs and it changes the engines profile.
