marble Posted April 11, 2014 Posted April 11, 2014 (edited) Is there any shorter decats about for td04 I have a toyo sport one at the moment but it hangs too low and my car scrapes on my flexi pipe because of this I can't put the car any lower Edited April 11, 2014 by marble Quote
mikey4410 Posted April 11, 2014 Posted April 11, 2014 they are all a standard height dude.im pretty sure the td04 ones hang as low as the ct9 decats also Quote
marble Posted April 11, 2014 Author Posted April 11, 2014 they are all a standard height dude.im pretty sure the td04 ones hang as low as the ct9 decats alsoActually looking at this photo I think it's the flexi and pipe after the decat that hang too low anyone any advice on this? Quote
JDMfreak Posted April 11, 2014 Posted April 11, 2014 looks like mine did its not the de-cat its the exhaust at the front people catch these and break them or flatten them then try weld a new bend into them but it needs to be a real sharp bend or better yet a angle job to get the exhaust to tuck back up under the sump so the exhaust doesn't droop after the cat and catch the ground you can see what mine was like the bits op pipe joined together I had to have the flexi part chopped out and the pipe at the bottom of the cat tucked up further so exhaust was closer to sump and a tiny flexi put in just so it had some movement but didn't hang Quote
marble Posted April 11, 2014 Author Posted April 11, 2014 (edited) looks like mine did its not the de-cat its the exhaust at the front people catch these and break them or flatten them then try weld a new bend into them but it needs to be a real sharp bend or better yet a angle job to get the exhaust to tuck back up under the sump so the exhaust doesn't droop after the cat and catch the groundyou can see what mine was like the bits op pipe joined together I had to have the flexi part chopped out and the pipe at the bottom of the cat tucked up further so exhaust was closer to sump and a tiny flexi put in just so it had some movement but didn't hangThanks buddy it's a pain in the hole I just want it dropped on it's arse but I can't or I'll say bye to my exhaust Edited April 11, 2014 by marble Quote
aidanep71 Posted April 12, 2014 Posted April 12, 2014 Just get a new front section made all exhausts I've seen for these hang really low by the sump and there's no need for it really. I got my custom system made and it's right up high the sump will hit the road now before the exhaust will Quote
JDMfreak Posted April 12, 2014 Posted April 12, 2014 what I would say is maybe a piece of pipe with a more of a curve from where it bolts to the bottom of the de-cat or cat and move the flexi back further so maybe more of a sweeping curve Quote
Glanza-Ben Posted April 12, 2014 Posted April 12, 2014 (edited) Toyo sports is your problem, everything they make is poor buildMy exhaust sits alot higher with a decent decat Edited April 12, 2014 by Glanza-Ben Quote
marble Posted April 12, 2014 Author Posted April 12, 2014 Toyo sports is your problem, everything they make is poor buildMy exhaust sits alot higher with a decent decatOh I know buddy it will be changed eventually Quote
hookie663 Posted April 12, 2014 Posted April 12, 2014 I'd get new front section made made get it up tight Quote
marble Posted April 14, 2014 Author Posted April 14, 2014 I'd get new front section made made get it up tightKnow anyone hookie? Quote
m_prior10 Posted April 14, 2014 Posted April 14, 2014 sean I got my custom made one made up at dees exhaust up beside abbey centre they do a brill job mine is tucked up.they do stainless steel powerflow ones so they will sort you out no probs Quote
