Glanza v Conversion Forged High Spec!
Year: 1997
Model: Toyota Starlet
Tax: 31/5/2014
MOT: February 2015
Mileage: Shell 80k Engine 15k
Description:
Looking for a new home for my Starlet as the time has come to buy a house, I don't want to sell the car but needing the funds for the house :(
I've been building the car over the last 2 years constantly sourcing parts and information off this forum and I wouldn't have had the car at the stage its at if it wasn't for this forum!
I've spent well over 10k on the car as most of the others on this forum probably have aswell, its been a pleasure to build and it is now at the stage I've always wanted it to be at.
Its powered by a forged 5e that I bought from Browner off here, he sold me the engine apparently 'good running condition' but it was fu**ed when I received it so its just had the cylinder head rebuilt in January this year including new Athena 1.4mm headgaket, new ARP headbolts, genuine Toyota valve stem oil seals, new timing belt, new 430cc injector, new adjustable FPR, new TD low temperature thermostat and also just been mapped at Tuning Developments on an E-manage Ultimate and one of their billet 300 td04 hybrid turbos which are very nice!
The car has made 275Bhp at 1bar of boost, it was mapped safely and is capable of upto 1.4bar of boost.
Prior to mapping the car had new rotor arm, new distributor, new spark plugs and new magnecore leads fitted.
I have receipts for all the recent work and a dyno printout.
ENGINE;
Forged 1.5 5EFTE
74.5 mm JE Pistons
5EFHE Conrods
ACL Bearings
1.4mm Athena Headgasket
ARP Head bolts
Cruise valve springs
5EFHE High lift cams
Full Toyota gasket kit
430cc injectors
TD Adjustable FPR
New timing belt
New distributor
New rotor arm
New megnecore leads
New spark plugs
The engine runs very well and is not laggy due to it being the 5E, also is running quite high compression between 180-190psi across the pistons so it also lively off boost.
GEARBOX;
The gearbox was rebuilt 5k ago and had genuine Toyota bearings fitted also had a paint job and looks good
Has a Quaiffe LSD fitted also which comes with original warranty
New 3E Flywheel fitted in December
Greddy Stage 2 paddle clutch covered less than 10k
TURBO/EXHAUST;
WEPR Ram horn external wastegate turbo kit with
WEPR Ram horn manifold
WEPR S/S Downpipe
WEPR S/S Screamer
Tial wastegate
Tuning Developments billet 300 td04 hybrid turbo Covered less than 2k
Has a Jperformance exaust fitted from the de-cat back
CHASSIS;
Meister r zeta r fully adjustable coilovers
Full car polybushed including engine mounts, wishbones and anti roll bar, except rear axel only thing I never done
Front upper strut brace
Front lower strut brace
Rear optional extra 3 point strut brace
Rota subzeros wit eagle f1 tyres very good tread
ELECTRONICS;
Greddy E-manage ultimate ecu with 3 bar map sensor and field harness
Greddy E-01 boost controller
Greddy Turbo timer
Walbro 255lph fuel pump
Alpine Head unit
Also has;
Jperformance front mount intercooler
Civic radiator
evo 8 recaros
Momo race steering wheel
The car has been fully undersealed over the last 2 years and the under body is very clean!
I had the car fully re-sprayed in Milano red just after I bought her.
It also has launch control which sound the muts nuts and works very well if its a dry day.
The paintwork on the wheels is in good condition but the polished lip could be doing with getting re-done, there are no curb marks.
It could easily be re-mapped with the current setup to 1.4 bar and should make a lot of power but im happy with it sitting at 275 as that's very fast and fast enough for me :)
If I was keeping the car I would have the wheels re-done and front bumper and bonnet painted due to stone chips which are to be expected for a car of this age.
The car comes with piles of paperwork and receipts.
Genuine interest only please and no timewasters.
I have probably missed loads of other bits and bobs.
Price: £6500 The price is high but its a high spec car that still has loads of potential for more power. If I don't get the price I want then I will have to break the car which I really don't want to do because it would break my heart after spending so much time and money building her :( although I would get more money if I break her, please someone give her a new home as I hate seeing good examples of these cars being broke for parts and really don't want this one to be another.
Contact Details: Contact Neil on 07572463350
Edited by rob_bower
